why so slow??!!
Old November 5th 05, 02:08 PM
Heino & Deanne Weisberg
Default why so slow??!!
I have a Stitts SA-3A playboy I picked up recently. It has an A-75
Continental and a 67" Fottorp prop with a 47 pitch. The plans indicate this
machine should fly around 120 mph with this engine; no mention of prop. A
previous owner I spoke to said it cruised around 118mph for him. For me, it
cruises around 95mph; I verified this with GPS. On run-up, I get about 2250
max RPM. On take-off it easily red-lines, suggesting to me the prop is not
a good match, but then I know next to nothing about this. It flies
beautifully, feels very well rigged. I won't pretend I know what the
problem could be; but I do know it is flying a lot slower than it should.
Any suggestions would be greatly appreciated!!
Thank you
Heino
Old November 5th 05, 03:01 PM
.Blueskies.
"Heino & Deanne Weisberg" wrote in message ...
I have a Stitts SA-3A playboy I picked up recently. It has an A-75 Continental and a 67" Fottorp prop with a 47 pitch.
The plans indicate this machine should fly around 120 mph with this engine; no mention of prop. A previous owner I
spoke to said it cruised around 118mph for him. For me, it cruises around 95mph; I verified this with GPS. On run-up,
I get about 2250 max RPM. On take-off it easily red-lines, suggesting to me the prop is not a good match, but then I
know next to nothing about this. It flies beautifully, feels very well rigged. I won't pretend I know what the
problem could be; but I do know it is flying a lot slower than it should. Any suggestions would be greatly
appreciated!!
Thank you
Heino
Is it knots on the GPS?
Old November 5th 05, 03:09 PM
Frank Stutzman
Before you start messing with the prop, I'd recommend making sure that
your tach is reading right.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old November 5th 05, 07:19 PM
Montblack
(".Blueskies." wrote)
95 knots = 109 mph
....which would help (half way to the wall) but he's still then missing
another 10%, from 109 mph up to 118 mph -120 mph.
Montblack
Old November 6th 05, 01:29 AM
Cy Galley
The A-75 gets its 75 HP by turning 2600. The Manual recommended cruise rpm
is 2350. I would check the timing as it is 29° for the top plugs (right
mag) and 32° for the bottom plugs. It is NOT timed the same as the A-65.
Cy Galley - Aeronca Aviators Club
Newsletter Editor & EAA TC
www.aeronca.org
Actively supporting Aeroncas every day
prop. A previous owner I spoke to said it cruised around 118mph for him.
For me, it cruises around 95mph; I verified this with GPS. On run-up, I
the prop is not a good match, but then I know next to nothing about this.
the problem could be; but I do know it is flying a lot slower than it
should. Any suggestions would be greatly appreciated!!
Thank you
Heino
Old November 6th 05, 12:59 PM
ASI is calibrated in mph, GPS is set to mph.
Heino
"Montblack" wrote in message
95 knots = 109 mph
Montblack
Old November 6th 05, 06:22 PM
The prop should be pitched to achieve redline RPM at full
throttle in level flight. Redlining in takeoff is not a good sign of a
suitable prop. And check that tach; most tachs any more than a few
years old tend to under-read as the magnet within tends to weaken as it
ages.
Dan
slow roll in a super decathlon Nobody Aerobatics 4 August 24th 05 02:36 AM
Wingtip Vortex: Heavy, Clean, Slow - Why? Eric Nospam Piloting 23 January 21st 05 03:09 AM
Flying Slow [email protected] Piloting 61 January 17th 05 05:23 PM
MP / FF guage slow to respond Steve Owning 2 May 17th 04 11:27 PM
Military Slow Routes R22AV8R Rotorcraft 0 April 17th 04 01:51 AM
