More grist for the battle of the battery
Old November 12th 05, 03:18 PM
COLIN LAMB
Default More grist for the battle of the battery
"Darn good idea, Larry. Even if you aren't messing
with a higher voltage battery. And put it in ths ship's
wiring. As I discovered, not everyone will use the
same connector with the same polarity."
A minor problem with this approach is that there will be a constant voltage
drop in the line. This is normally no concern, except when you are down to
the low end of the battery range. Then, you have just increased the minimum
voltage by .5 volts.
You can avoid this problem by connecting the diode differently. In this
case, you would connect a diode across the radio. Connect the cathode
(banded end) across the + and the anode across the - . The current capacity
of the diode must be greater than the fuse or circuit breaker. Make sure
there is a fuse or circuit breaker in the line before the battery connector.
If the polarity is correct, the diode will be invisible - hence no voltage
loss. If the polarity is backwards, the diode will short out, blowing the
fuse or circuit breaker. Opposite polarity voltage will not exceed about .5
to .7 volts, which will not damage the radio.
Colin
More grist for the battle of the battery Bill Daniels Soaring 27 November 16th 05 02:19 AM
60 years from Battle of Tali-Ihantala June-July 1944 - which decidedthe fate of Finland Jukka O. Kauppinen Military Aviation 1 June 29th 04 03:00 PM
14 Volt Gel Cell? Joe Allbritten Soaring 32 May 11th 04 01:37 AM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 01:29 PM
Becker AR 4201 or Microair 760 Transceiver Steve B Soaring 23 September 15th 03 06:32 PM
