does a plane have to have
all three elements (flaps, retractable landing gear AND a constant speed prop.) or if it has just one (retractable langing gear OR a constant speed prop.), does that make it complex? 61.31 (e) (1) ....and... You need all three for it to be complex. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
On Fri, 18 Nov 2005 21:19:40 GMT, Jose
wrote: does a plane have to have all three elements (flaps, retractable landing gear AND a constant speed prop.) or if it has just one (retractable langing gear OR a constant speed prop.), does that make it complex? 61.31 (e) (1) ...and... You need all three for it to be complex. Wasn't that changed in the not too distant past? Seems like when I started flying it only took two of the three. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Jose |
Wasn't that changed in the not too distant past? I meant three wheels. Not three wiggles. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
That is to say (sheesh, doesn't Jose snip properly!)... You need all three wiggles, but only one wheel needs to wiggle. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
On Sat, 19 Nov 2005 23:42:01 GMT, Jose
wrote: You need all three for it to be complex. Wasn't that changed in the not too distant past? I meant three wheels. Not three wiggles. I meant Constant speed prop, Electric flaps, and retract.:-)) Didn't it used to be only two of the three required for complex? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Jose |
Didn't it used to be only two of the three required for complex? For seaplanes, retractable gear is not necessary. However as long as I remember it was all three wiggles for land planes. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Flaps do not have to be electrified..just gotta have em
"Jose" wrote in message .. . I meant Constant speed prop, Electric flaps, and retract.:-)) Didn't it used to be only two of the three required for complex? For seaplanes, retractable gear is not necessary. However as long as I remember it was all three wiggles for land planes. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
Passenger crash-lands plane after pilot suffers heart attack | R.L. | Piloting | 7 | May 7th 05 11:17 PM |
Navy sues man for plane he recovered in swamp | marc | Owning | 6 | March 29th 04 12:06 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
