Good AI backup, wish me luck
Old March 1st 04, 01:06 AM
Ray Andraka
I'm surprised no one has mentioned wet vacuum pumps. I'm considering a
wet pump when the current dry pump gives up the ghost, as it sounds like
wet pumps are nearly bullet-proof. That said, I have been lucky in that I
still have not had a vacuum pump go out on me. I have had several gyros
fail though.
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old March 1st 04, 02:00 AM
John R. Copeland
If you already have a few oil leaks, then the wet pump won't annoy you.
Those oil/air separators in the discharge are not perfect.
---JRC---
"Ray Andraka" wrote in message =
I'm surprised no one has mentioned wet vacuum pumps. I'm considering =
a
wet pump when the current dry pump gives up the ghost, as it sounds =
like
wet pumps are nearly bullet-proof. That said, I have been lucky in =
that I
still have not had a vacuum pump go out on me. I have had several =
gyros
fail though.
=20
Old March 1st 04, 02:22 AM
Ash Wyllie
Ray Andraka opined
fail though.
At one point I thought about replacing the dry pumps on a Twin Comanche with
wet ones. Seems that you need to go through a bunch of STC or 337 field
approval paper work to do the swap. So I dropped the idea.
-ash
Cthulhu for President!
Why vote for a lesser evil?
Old March 1st 04, 02:48 AM
John R. Copeland
"Ash Wyllie" wrote in message =
Ray Andraka opined
=20
a
like
that I
gyros
fail though.
=20
At one point I thought about replacing the dry pumps on a Twin =
Comanche with
wet ones. Seems that you need to go through a bunch of STC or 337 =
field
=20
=20
I don't know about Lycoming engines, but Continentals still have the oil =
galleries
under the mounting pads for the vacuum pumps.
I know because I recently had to replace a leaking seal on one of my dry =
pumps.
Probably a simple 337 would suffice for Continentals.
You'd just be changing back to the configuration they were originally =
designed for.
---JRC---
Old March 1st 04, 05:36 PM
Ray Andraka
Mine (a '65 model) originally had a wet pump, and I believe it is what is listed
on the TC.
-ash
--Ray Andraka, P.E.
email
Good plans-built Light Sport Aircraft Rob Schneider Home Built 15 August 19th 04 05:50 PM
Free Volksplane to good home, located in Chino Hills CA Bryan Zinn Home Built 3 July 18th 04 02:55 AM
Solid State Backup AI Dan Truesdell Instrument Flight Rules 20 January 15th 04 09:53 PM
Good Luck, Jim! Rich S. Home Built 203 November 4th 03 11:46 PM
bulding a kitplane maybe Van's RV9A --- a good idea ????? Flightdeck Home Built 10 September 9th 03 07:20 PM
