![]() "Jay Beckman" wrote in message news:9Ajlf.20$6N2.14@fed1read06... "Dudley Henriques" wrote in message k.net... Unusually high nose attitudes in power on stalls are almost always the result of an improper set up for doing the stall. This involves excessive energy (airspeed) that has to be bled off, especially in airplanes with fairly powerful engines. There's no need for an excessively high nose attitude when doing a power on stall. Try slowing the airplane first by throttling on back while rotating in pitch, right on down to normal climb speed, then continue to rotate in pitch while applying climb power to a normal climb attitude . From there simply continue to increase pitch smoothly on into critical angle of attack where the stall will occur. Dudley Henriques How true... After my first couple of attempts, my instructor (semi jokingly) admonished me for attempting to perform a loop. I saw Richard Petty try this at Telladega once, but the fence got in the way and spoiled it for him. :-) D |
.net... "Jay Beckman" wrote in message news:9Ajlf.20$6N2.14@fed1read06... "Dudley Henriques" wrote in message k.net... Unusually high nose attitudes in power on stalls are almost always the result of an improper set up for doing the stall. This involves excessive energy (airspeed) that has to be bled off, especially in airplanes with fairly powerful engines. There's no need for an excessively high nose attitude when doing a power on stall. Try slowing the airplane first by throttling on back while rotating in pitch, right on down to normal climb speed, then continue to rotate in pitch while applying climb power to a normal climb attitude . From there simply continue to increase pitch smoothly on into critical angle of attack where the stall will occur. Dudley Henriques How true... After my first couple of attempts, my instructor (semi jokingly) admonished me for attempting to perform a loop. I saw Richard Petty try this at Telladega once, but the fence got in the way and spoiled it for him. :-) D LOL. I'd have to declare most of NASCAR's car-obatics closer to "Lomcvaks" (Sp?) than anything else... Couple of guys have done some pretty good axial rolls and the occassional 'Very Low Inverted Pass." Jay B |
![]() "Jay Beckman" wrote in message news:Kfqlf.78$6N2.66@fed1read06... "Dudley Henriques" wrote in message .net... "Jay Beckman" wrote in message news:9Ajlf.20$6N2.14@fed1read06... "Dudley Henriques" wrote in message k.net... Unusually high nose attitudes in power on stalls are almost always the result of an improper set up for doing the stall. This involves excessive energy (airspeed) that has to be bled off, especially in airplanes with fairly powerful engines. There's no need for an excessively high nose attitude when doing a power on stall. Try slowing the airplane first by throttling on back while rotating in pitch, right on down to normal climb speed, then continue to rotate in pitch while applying climb power to a normal climb attitude . From there simply continue to increase pitch smoothly on into critical angle of attack where the stall will occur. Dudley Henriques How true... After my first couple of attempts, my instructor (semi jokingly) admonished me for attempting to perform a loop. I saw Richard Petty try this at Telladega once, but the fence got in the way and spoiled it for him. :-) D LOL. I'd have to declare most of NASCAR's car-obatics closer to "Lomcvaks" (Sp?) than anything else... Couple of guys have done some pretty good axial rolls and the occassional 'Very Low Inverted Pass." Jay B :-) I had a sort of comedy routine I'd go through in the S2 Pitts while taxiing out to enter a lesson with a student who was going to be doing his first Lommy. I'd describe it to him something like this on the intercom. "Just give me a 45 degree up line with full power and let the airspeed drain back to 80. Then give me full right rudder, full left aileron, and full forward stick simultaneously. Shut your eyes cause it's gonna scare the living s**t out of you, count 3 seconds and open 'um again. You'll have done your first Lomcevak!!! But don't go to sleep yet!!!!!!! At second 4 we'll be learning all about inverted spin recovery". :-))) Dudley |
.net... I had a sort of comedy routine I'd go through in the S2 Pitts while taxiing out to enter a lesson with a student who was going to be doing his first Lommy. I'd describe it to him something like this on the intercom. "Just give me a 45 degree up line with full power and let the airspeed drain back to 80. Then give me full right rudder, full left aileron, and full forward stick simultaneously. Shut your eyes cause it's gonna scare the living s**t out of you, count 3 seconds and open 'um again. You'll have done your first Lomcevak!!! But don't go to sleep yet!!!!!!! At second 4 we'll be learning all about inverted spin recovery". :-))) Dudley Ah, "Bonus Maneuver" !! Nice! Jay B |
![]() "Jay Beckman" wrote LOL. I'd have to declare most of NASCAR's car-obatics closer to "Lomcvaks" (Sp?) than anything else... Couple of guys have done some pretty good axial rolls and the occassional 'Very Low Inverted Pass." Yea, but they all bounced their landings! g -- Jim in NC |
"Morgans" wrote in message
news ![]() "Jay Beckman" wrote LOL. I'd have to declare most of NASCAR's car-obatics closer to "Lomcvaks" (Sp?) than anything else... Couple of guys have done some pretty good axial rolls and the occassional 'Very Low Inverted Pass." Yea, but they all bounced their landings! g -- Jim in NC Gives new meaning to the old saw about "Any landing you can walk away from..." Jay B |
![]() "Jay Beckman" wrote Gives new meaning to the old saw about "Any landing you can walk away from..." Yeaah, but they were definitely not great landings, cause that equipment will *never* be able to be used again! g -- Jim in NC |
... "Jay Beckman" wrote Gives new meaning to the old saw about "Any landing you can walk away from..." Yeaah, but they were definitely not great landings, cause that equipment will *never* be able to be used again! g -- Jim in NC Aw c'mon, you aren't giving the guys in the Fab shops any credit!! They can make chicken salad out of chickensh*t ! I'd be very suprised to find out that any chasis that a driver really likes ever goes completely away. Sort of like a quality airframe...they get recycled, don't they? There...back On Topic... ;O) Jay B |
![]() "Jay Beckman" wrote Aw c'mon, you aren't giving the guys in the Fab shops any credit!! They can make chicken salad out of chickensh*t ! I'd be very suprised to find out that any chasis that a driver really likes ever goes completely away. Sort of like a quality airframe...they get recycled, don't they? There...back On Topic... Depends. One that llloops and rrrolls before they crash can't be fixed. Once they have that many bbbends and cccracks, like Fetter's frames, they become flower planters. Difference is, the drivers almost always live. See, I can stay on topic, too! ;-)) -- Jim in (the NASCAR state of) NC |
FA: Jeppesen Private Pilot Training kit | Andy | Aviation Marketplace | 0 | October 18th 04 04:30 PM |
Can a Private Pilot tow gliders and get paid? | BTIZ | Soaring | 1 | October 17th 04 01:35 AM |
Self fly hire in the US | Nigel | Piloting | 25 | March 28th 04 09:20 AM |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
