Barry,
You are going to get some advise that will possibly get the computer controller working correctly, for the most part, on your engine. Let's see if I can point out some things that would make you go a different route. Regardless of the dependability of these computers on automobiles, and I am going to use a cliché, you can't pull over to the side of the road when the system quits. Hundreds and hundreds of Subarus have been installed and flown with the automotive electronic controls. The failure rate of these installations has been a part of the problem with the reduced availability of insurance for auto-conversions. THe first problem is figuring out the sensors and settings just as you are finding right now. The next problem is redundancy. As dependable as you may think this computer control is, they are susceptible to vibration and in a few cases RF transmissions. There needs to be full redundancy with a complete second computer that can be switched into operation if a failure occurs on the primary system. One of the advantages of an automotive engine conversion has been simplicity; something that can be repaired in the boonies. Mechanical fuel injection can meet that requirement but is usually a high maintenance setup. Carbs have been the choice because they have a century's worth of refinement and by electronic fuel injection standards are dirt simple. There are few places in the world where you cannot get parts for a Holley. If your EFI is a throttle body type you will find that bolting on a mechanically operated unit like the Ellison "throttle body" retains the performance and simplifies operation. If your EFI is a direct injection setup you can find an aftermarket controller available from race car catalogs that is easier to back up with a second unit for redundancy. If you retain the OEM automotive computer, the minimum safe set up would be to obtain a second unit from a salvage yard and install it to allow easy switching when the primary unit fails. Salvage yard prices for the engine control computers is is usually in the range of $200 versus $2000 from the dealer. Backup should include a stand by coil and other parts of the ignition system depending on how inclusive are the components on the control computer. Barry Palmer wrote: Anyone out there work with EFI engines. I have a 4.3L Chevy V-6 that was removed from a car with its ECU and when operated with a propeller load does not want to get above 1500rpm, (should go to 4200rpm) while it hunts up and down for the correct mixture ratio. The transmission is removed, if there are any sensors on it they are caput. I hate to just blame it on the O2 sensor. Anyone have any suggestions as to newsgroups in the hot rod area that work with the ECU's? Barry Palmer, for Sevtec (http://members.aol.com/sevtec/sev/skmr.html) -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding |
