![]() "xerj" wrote in message ... ... why does an increase in temperature mean an increase in the speed of sound? That's got me confused. Hotter = less dense. Thanks in advance. The speed of sound varies with temperature alone. |
In article et,
"Steven P. McNicoll" wrote: "xerj" wrote in message ... ... why does an increase in temperature mean an increase in the speed of sound? That's got me confused. Hotter = less dense. Thanks in advance. The speed of sound varies with temperature alone. The speed of sound varies with temperature and type of medium. -- Bob Noel New NHL? what a joke |
Bob Noel wrote:
Thanks in advance. The speed of sound varies with temperature alone. The speed of sound varies with temperature and type of medium. The speed of sound in air varies almost solely with temperature. For other types of mediums, the temperature is less of a factor. The general formula for the speed of sound is the density divided by the bulk modulus. The issue is that with gases the other variables in the equation all cancel each other out. In water for example, density is a MAJOR factor. The speed of sound in salt water is faster than fresh water in addition to temperature. |
Ron Natalie wrote:
Bob Noel wrote: Thanks in advance. The speed of sound varies with temperature alone. The speed of sound varies with temperature and type of medium. The speed of sound in air varies almost solely with temperature. For other types of mediums, the temperature is less of a factor. The general formula for the speed of sound is the density divided by the bulk modulus. The issue is that with gases the other variables in the equation all cancel each other out. In water for example, density is a MAJOR factor. The speed of sound in salt water is faster than fresh water in addition to temperature. Commpressibility is the major factor. Water isn't very compressible and transmits sound quite well, but air is and sound dissipates. Frequency dispersion which has to do with how well various frequencies are transmitted, affects how much the receiver will understand what is being sent. It is an exceedingly complicated phenomenom -- ask any sonar designer or a Navy weapons person. |
![]() "Ron Natalie" wrote in message m... Bob Noel wrote: Thanks in advance. The speed of sound varies with temperature alone. The speed of sound varies with temperature and type of medium. The speed of sound in air varies almost solely with temperature. For other types of mediums, the temperature is less of a factor. The general formula for the speed of sound is the density divided by the bulk modulus. The issue is that with gases the other variables in the equation all cancel each other out. In water for example, density is a MAJOR factor. The speed of sound in salt water is faster than fresh water in addition to temperature. You're mixing apples and oranges. Water (H2O) does not equal salt water (H2O + NaCl). They are two different media. Just as air is a nominal mix of N + O + a few other gasses. Change that mix and it's a different media with a different gamma and bulk modulus (R). So your density change is really a change in media. If the media doesn't change, density doesn't have an effect on the speed of sound. Changing the media changes the gamma and R; but for any one specific media, only temperature will cause a change in the speed of sound. Gerry |
![]() "Bob Noel" wrote in message ... The speed of sound varies with temperature and type of medium. The medium under discussion per the subject line is air. Since this is a piloting group it can be reasonably assumed to be air at temperatures found in the atmosphere. Air at atmospheric temperatures behaves as an ideal gas and the speed of sound in an ideal gas is a function of temperature. |
Deriving the sonic velocity is one favorite question for the final exam
of mechanical engineering thermodynamics courses. From my old textbook: "in an ideal gas the sonic velocity depends only on the molecular weight and the absolute temperature (degF + 460), and is proportional to the square root of that absolute temperature". |
On 17 Dec 2005 09:45:07 -0800, "nrp" wrote in
.com:: "in an ideal gas the sonic velocity depends only on the molecular weight and the absolute temperature (degF + 460), and is proportional to the square root of that absolute temperature". In which units does that equation provide the sonic velocity? More he http://roger.ecn.purdue.edu/~aerodyn...Lecture06.html |
When I took thermo, there were only ft lbs, BTUs, and lbm. It was a
lot simpler before Metric became PC. (I wonder how we happened to keep seconds?) |
![]() "nrp" wrote in message oups.com... When I took thermo, there were only ft lbs, BTUs, and lbm. It was a lot simpler before Metric became PC. I found the MKS system to be simpler. |
speed record set by scramjet - fair? | Don French | Piloting | 55 | November 28th 04 01:57 PM |
Space Elevator | Big John | Home Built | 111 | July 21st 04 04:31 PM |
How Aircraft Stay In The Air | Sarah Hotdesking | Military Aviation | 145 | March 25th 04 05:13 PM |
Va and turbulent air penetration speed. | Doug | Instrument Flight Rules | 70 | January 11th 04 08:35 PM |
Kestral 1000 Wind Speed Meter NEW IN BOX | Cecil E. Chapman | Products | 0 | November 7th 03 06:56 PM |
