winglets
Old January 7th 06, 01:22 AM
clipclip clipclip is offline
Junior Member
First recorded activity by AviationBanter: Nov 2005
Quote:
Originally Posted by bagmaker
OK, I can get the theory (OR can I?) with winglets to reduce wingtip vortices.
Surely the best direction for the tip is DOWN!, [...] Enlighten me, O knowledgable ones!
i'm certainly not that knowledgeable person, but i have heard people whom i would consider quite knowledgeable say that the orientation of the winglet really doesn't matter - it could be flat, or pointed down. either way it reduces induced drag. however, costly hangar space is costlier if the wingspan is wider, and i imagine crosswind landings could become more interesting with winglets pointed down.
frank
Old January 7th 06, 07:50 AM posted to rec.aviation.soaring
Default winglets
It does matter. The pressure on the top side of the wing I a lot lower
that the surrounding air, the overpressure on the downside only a bit
higher. That way it makes sense.
For avery angle of attack (Cl) there is an optimum configuration,
usually a double eliptical shape. (Bend up like a Discus-2, a bit the
shape of an ls-6/8)
Alhoewel real life deals with Reynolds and sideslip whick makes is a
lot more complicated.
For the jetliners, a very small "extra" inverted winglet clearly lowers
the vortices. Also dependant of cruise Cl, Reynolds, mach number.
Jarno Nieuwenhuize
The Netherlands.
LS4 Winglets Sleigh Soaring 2 June 8th 05 01:38 AM
Ventus A 16.6 extensions wanted or 15 meter winglets goneill Soaring 0 January 5th 05 06:27 AM
winglets for LS-1 Brad Soaring 4 October 26th 04 06:11 PM
ASW20L extentions with winglets? goneill Soaring 6 September 17th 04 10:28 PM
Discus Winglets Kevin Neave Soaring 2 October 15th 03 11:35 AM
