How well does auto gas mix with 100LL?
LJ |
On Fri, 20 Jan 2006 18:48:31 -0700, LJ wrote:
How well does auto gas mix with 100LL? I've had no problem with it. I've done a fill with 100LL every ~4 fill-ups to keep up the lead levels. This time of year, I run 100% 100LL because of stability. Never had a problem with mixing the fuels. Ron Wanttaja |
Thank Ron!
I have the Rotax,But have been using 100LL.Thanks Again! LJ Ron Wanttaja wrote: On Fri, 20 Jan 2006 18:48:31 -0700, LJ wrote: How well does auto gas mix with 100LL? I've had no problem with it. I've done a fill with 100LL every ~4 fill-ups to keep up the lead levels. This time of year, I run 100% 100LL because of stability. Never had a problem with mixing the fuels. Ron Wanttaja |
LJ,
How many hours do you have on your Rotax? I've heard that running 100LL requires more frequent oil, filter, and spark plug changes. What is your experience? So far, I've been avoiding avgas, and have managed to run mine 120 hours on mogas exclusively. tom |
On Fri, 20 Jan 2006 19:50:56 -0700, LJ wrote:
Ron Wanttaja wrote: How well does auto gas mix with 100LL? I've had no problem with it. I've done a fill with 100LL every ~4 fill-ups to keep up the lead levels. This time of year, I run 100% 100LL because of stability. Never had a problem with mixing the fuels. Ron Wanttaja Thank Ron! I have the Rotax,But have been using 100LL.Thanks Again! Ummm, my experience on a Continental only, so I'm not sure how it relates to the Rotax. I don't believe the fuel chemistry is adversely affected, but it does mean you've got leaded fuel. If the Rotax can stand lead, you're probably OK. Ron Wanttaja |
about 150hr,I changed plugs at 100hr.they were leaded up but were firing
ok.On the oil part of lead,I havn't had the same problem.Maybe-becaues I changed oil more often.(My plane is one of the Caldwell,Id builders group. wrote: LJ, How many hours do you have on your Rotax? I've heard that running 100LL requires more frequent oil, filter, and spark plug changes. What is your experience? So far, I've been avoiding avgas, and have managed to run mine 120 hours on mogas exclusively. tom |
| Thread Tools | |
| Display Modes | |
