Stuart Grey wrote:
So, what's the deal with Raymer's book? Does it have an excessive margin of safty, or was I doing something wrong? After playing with the spreadsheet for about 15 minutes, it looks as though the weight calcs are VERY sensitive to a few parameters that aren't well explained in the spreadsheet. Unless you know exactly what those parameters are, I don't think you should trust the weight #'s that you get. Maybe the book has in-depth explanations of what the parameters are and how to set them. -- Marc J. Zeitlin http://www.cozybuilders.org/ Copyright (c) 2006 |
Marc J. Zeitlin wrote:
Stuart Grey wrote: So, what's the deal with Raymer's book? Does it have an excessive margin of safty, or was I doing something wrong? After playing with the spreadsheet for about 15 minutes, it looks as though the weight calcs are VERY sensitive to a few parameters that aren't well explained in the spreadsheet. Unless you know exactly what those parameters are, I don't think you should trust the weight #'s that you get. Maybe the book has in-depth explanations of what the parameters are and how to set them. Yes, I needed to understand the parameters, and they were explained better later in the book.. The book is kind of pricy for the number of pages, but on the other hand, it gets to the core of what you need to know without a lot of (unnecessary) theory and explaination, so you're getting good bang for the buck. I can relate to that. My problem came from the parameter "a". The book gives 1.19 for a single engine, metal design - and this is the paramter I used. Way in the back of the book, on page 135 (yeah, it's not a thick book) it shows how the parameter a is calculated. You should find similar planes to the one you want to build, and find the ratio of their empty weight to fully loaded weight, and graph that on a chart against the fully loaded weight. Among home built planes, there is a large cluster near 0.6-0.65 for We/Wo, resulting in an a of over 1.2. However, there is another cluster near 0.45 to 0.59 that result in an a closer to an a of 1.0 or below. I think the airplane I want to build is in this grouping and not the other. I suspect the difference is the smaller grouping is a high wing with struts, while the other grouping is a low strutless wing. It appears to be worthwhile to read the entire book. :-) Doh! |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 1 | January 2nd 04 09:02 PM |
