clare at snyder.on.ca wrote in message
... On Fri, 10 Feb 2006 16:28:10 GMT, Alan Baker wrote: In article .com, wrote: But when we DO use 'horsepower' we must be careful to never use it in isolation, always identifing the rotational speed at which that 'horsepower' is being produced. Absolutely and utterly wrong. It is *torque* which must always be associated with the rotational speed at which it is being produced. Read that first sentence again. He's not wrong; he just didn't specify "torque" for those who don't know the relationship between it and RPM and HP. When you say "absolutely and utterly" it should be used only where it applies. Clearly, that's not here. But that's my point. He is absolutely and utterly wrong, when he says that you need to know the rotational speed before you know all you need to know when you know the horsepower. With horsepower, you can use gearing to get any rotational speed you want; the horsepower remains constant. Torque changes with gearing. Yes, you CAN use gearing, at the expense of complexity.And efficiency. Much better to design the engine to produce the power you need at the speed you need it. However, sometimes you trade efficiency and durability for weight - and a geared 1.2 liter 80 hp engine running at 6000 RPM can weigh significantly less than a direct drive 2.7 liter engine providing the same power at 2800 rpm. (well, about 40 lbs less, anyway) Ya' know ... there is a real problem with this entire discussion. Not just this latest thread, but the discussion in general, and I really feel a need to mention it before I turn in for the night--which is another ting that I fell a need to do. The problem, as I see it, is that there may be nearly as much difference between different kinds of airplanes as there is between the different kinds of ground vehicles that can be operated on public roads. That's just counting airplanes, not helicopters, etc... And we can probably all agree that a faster airplane can efficiently use a smaller, and faster turning, prop for its horsepower than can a slower airplane. Some of us are mostly interested in airplanes that really need a redrive to get good propeller efficiency from a 40 HP VW. Others are interested in slippery airplanes that cruise at 150 to 200 kts. My interest is in the faster type of airplane, and the only reason the specification isn't for something even faster is a desire to keep the simplicity of a fixed pitch prop. Therefore, if I want to use the old formula of 0.2G static thrust for good takeoff performance on a 150 kt airplane, I only need to divide the expected gross weight of the airplane by 10 to arrive at a reasonable horsepower figure. (Since I want a static thrust of one fifth of the gross weight, and also since each horsepower results in 2 pounds of thrust at the 150 kt speed--or would if efficiency was 100%) I really DON'T care about efficiency, because I only intend to operate at low speed and high power for less than a minute per flight. Propeller efficiency will always be zero, by mathematical definition, at the beginning of the take off roll; and my numbers work just fine with 40% efficiency during the initial climb to clear the obstacles. On the other hand, if your plan is to cruise at 60 kts, with a proportionately slower initial climb speed, then you probably need a larger diameter prop than I do, even with a much lighter and less powerful airplane. We really need to look at what is workable, reliable, and affordable for each specific application. I admit to being a long time advocate of automotive conversions, and the various GM and D-C all aluminum 60 degree V6s from 3.0 to 3.7 liters really do look promising; but I really would have to think long and hard before I trying to adapt one to an airplane that has already been designed around a standard airplane engine. Just making the cooling system work reliably, with reasonable drag, would probably cause insomnia! Peter |
Peter Dohm wrote:
but I really would have to think long and hard before I trying to adapt one to an airplane that has already been designed around a standard airplane engine. Just making the cooling system work reliably, with reasonable drag, would probably cause insomnia! Peter Designing a proper cooling system for a wet engine really isn't that difficult. Air cooled engines have a much higher delta-T, but their cooling surface area is extremely limited. Radiators have a much lower delta-T, but thousands of square inches of surface. The problem is that most people havn't the slightest clue or any inclination to get one as to what the air is doing around the cooling surfaces or how to make it better. The secret is to make the air pass straight through the radiator vanes so that both sides are cooled. Rotaries using air-conditioner cores as radiators are flying very successfully. Have been for years. Only requires 2 13'x9'x3' cores. Mine will be installed in the wing strakes. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
![]() "Peter Dohm" wrote in message ... Some of us are mostly interested in airplanes that really need a redrive to get good propeller efficiency from a 40 HP VW. Others are interested in slippery airplanes that cruise at 150 to 200 kts. My interest is in the faster type of airplane, and the only reason the specification isn't for something even faster is a desire to keep the simplicity of a fixed pitch prop. Therefore, if I want to use the old formula of 0.2G static thrust for good takeoff performance on a 150 kt airplane, I only need to divide the expected gross weight of the airplane by 10 to arrive at a reasonable horsepower figure. (Since I want a static thrust of one fifth of the gross weight, and also since each horsepower results in 2 pounds of thrust at the 150 kt speed--or would if efficiency was 100%) I really DON'T care about efficiency, because I only intend to operate at low speed and high power for less than a minute per flight. Propeller efficiency will always be zero, by mathematical definition, at the beginning of the take off roll; and my numbers work just fine with 40% efficiency during the initial climb to clear the obstacles. On the other hand, if your plan is to cruise at 60 kts, with a proportionately slower initial climb speed, then you probably need a larger diameter prop than I do, even with a much lighter and less powerful airplane. We really need to look at what is workable, reliable, and affordable for each specific application. I admit to being a long time advocate of automotive conversions, and the various GM and D-C all aluminum 60 degree V6s from 3.0 to 3.7 liters really do look promising; but I really would have to think long and hard before I trying to adapt one to an airplane that has already been designed around a standard airplane engine. Just making the cooling system work reliably, with reasonable drag, would probably cause insomnia! Peter I recommend Fred Weick's book on Propellor Design. I think you will find that the thrust per horsepower is not a constant but rather decays proportionately to the log of the RPM. The pounds of thrust per horsepower gets pretty punk past about 2500 RPM of the prop. At 1000 RPM you get great thrust out of 25 or 30 horsepower! At 2500 RPM you can get the same thrust from 100 HP with a good prop! :-) Highflyer Highflight Aviation Services Pinckneyville Airport ( PJY ) |
Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 04:05 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
automotive parts on airplane engines | Wallace Berry | Home Built | 15 | September 28th 03 02:55 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
