Richard Riley wrote:
RS, it pleases me greatly when I find I've come to the same conclusions as you. I'm just finishing work on a cheap slow flier. It's a departure from standard, at least for the wing, so I've overengineered the safety side (BRS, 5 point harness and a pilot's parachute). But for instrumentation, I'm minimal. Handheld GPS and com (since I'm in the busy traffic of So Cal, I'm addicted to com) EGT and CHT for the single cylender 2 stroke. RPM. Fuel level is visible. Altimiter - So I can get a good idea of rate of climb. Airspeed is a plastic tube with a red plastick floatie disk. That's it. OTOH, I have the Uber Panel in the expensive fast flier. Two missions, two solutions. I guess I'm a hard headed old coot. (well, DuH!) I simply won't fly a two-stroke without an EGT. Problem, though, is that the EGT runs so (you favorite explicative) high anyway that a micro seizure can put it over the limit in a mater of seconds. You'd almost have to be staring at it to notice a needle or two width jump. Specially on the little 2: gauges with a short swing! I've always wanted to ask Jim if there was a simple circuit that could monitor the EGT and notice the RATE of increase that would indicate a pending problem rather that an already existing one. Maybe blink a light, ring a bell, or apply electric shock as needed? Jim, anything in you S&M cap that might work here? Rich(OUCH)ard |
Sadism & Machochism?
The problem resolves itself to dicking around with a thermocouple probe that puts out millivolts and then picking out the microvolt rise that indicates a rate increase. Can it be done? Sure. Easily? Perhaps. Trivially? Probably not. The second problem, generated by the first, is simulating such a rise and setting the trigger in the simulation. I'm presuming that you don't want to sacrifice an engine to calibrate the rascal. Then the question becomes, what rate do you want to trigger? One degree a second? Ten? A hundred? Or what rise over what time are you interested in? Form the problem and I'll try and come up with a solution. Jim I've always wanted to ask Jim if there was a simple circuit that could monitor the EGT and notice the RATE of increase that would indicate a pending problem rather that an already existing one. Maybe blink a light, ring a bell, or apply electric shock as needed? Jim, anything in you S&M cap that might work here? Rich(OUCH)ard |
RST Engineering wrote:
Sadism & Machochism? The problem resolves itself to dicking around with a thermocouple probe that puts out millivolts and then picking out the microvolt rise that indicates a rate increase. Can it be done? Sure. Easily? Perhaps. Trivially? Probably not. The second problem, generated by the first, is simulating such a rise and setting the trigger in the simulation. I'm presuming that you don't want to sacrifice an engine to calibrate the rascal. Then the question becomes, what rate do you want to trigger? One degree a second? Ten? A hundred? Or what rise over what time are you interested in? Form the problem and I'll try and come up with a solution. Jim I see your point, Jim. I guess the "rate" suggestion is a non-starter as it would also likely vary considerably between engine types. Dropping that one and looking at it as a max limit indicator would still require rather delicate calibration, but would it be more do-able then? The Leaf catalog doesn't mention EGT limits for the Rotax engines. I would think a trip point just below MAX EGT (~1100 ~1200 degrees F). There is also the issue of how and where the EGT probes are installed. A little closer to the exhaust port will read higher and vice versa. I dunno, Jim. I'd really like to have something like this (that works!), but maybe I'm asking for too much? Richard There's been a lot of "strangeness" on the net the last few days. Lot's of 404s and "cannot decrypt document" errors. Is it me, or the weather still causing problems? But this one did work...582 max egt = 1200F FilePath=upload/techdocs/2004611123380.HM11_2.pdf |
In article . net,
Richard Lamb wrote: I dunno, Jim. I'd really like to have something like this (that works!), but maybe I'm asking for too much? Richard When recumbent bike guy was in here, we talked about curing ovens for composites, and that brought up temperature control units. Those things use rate of change to avoid temperature overshoot by scaling back power as the set point is approached. You do something analogous to this every time you take your foot off the gas and then begin to brake gently, as you approach a stop sign. But, the point is, I think you might be able to find an off the shelf solution. There's nothing terribly sophisticated about a speedometer. In this case, you want to measure something like degrees per minute instead of miles per hour. |
![]() You mean something like this? Cabelas.com Item # :IG-521411 or jcwhitney.com # ZX133955X |
Smitty Two wrote:
In article . net, Richard Lamb wrote: I dunno, Jim. I'd really like to have something like this (that works!), but maybe I'm asking for too much? Richard When recumbent bike guy was in here, we talked about curing ovens for composites, and that brought up temperature control units. Those things use rate of change to avoid temperature overshoot by scaling back power as the set point is approached. You do something analogous to this every time you take your foot off the gas and then begin to brake gently, as you approach a stop sign. But, the point is, I think you might be able to find an off the shelf solution. There's nothing terribly sophisticated about a speedometer. In this case, you want to measure something like degrees per minute instead of miles per hour. Good example, but WAY more involved here. I've fooled around with it some myself, but my experience is in logic design, not the weird and wonderful world of analog electronics. Jim's point (as I read it) was that we'd have to notice (and react to) a few microvolts change - per second - (the RATE question). But how many mV per second would be considered a threatening situation? (i.e.: how many degrees per second) In the automobile example the question might be framed, "What rate of closure would prompt you to lift the gas pedal and apply the brakes?". Answer - Depends on how close you are to the thing in front of you. Jim's response was It seems like a fairly simple request on the surface, but too many undefined variables for a simple answer. There is going to be a bit of research involved before this one can be worked out. Richard My ex has a cute "old saying" that she came up with. "Two weeks in the lab will save you three days in the library every time". |
In article et,
Richard Lamb wrote: When recumbent bike guy was in here, we talked about curing ovens for composites, and that brought up temperature control units. Those things use rate of change to avoid temperature overshoot by scaling back power as the set point is approached. You do something analogous to this every time you take your foot off the gas and then begin to brake gently, as you approach a stop sign. But, the point is, I think you might be able to find an off the shelf solution. There's nothing terribly sophisticated about a speedometer. In this case, you want to measure something like degrees per minute instead of miles per hour. Good example, but WAY more involved here. I've fooled around with it some myself, but my experience is in logic design, not the weird and wonderful world of analog electronics. Jim's point (as I read it) was that we'd have to notice (and react to) a few microvolts change - per second - (the RATE question). But how many mV per second would be considered a threatening situation? (i.e.: how many degrees per second) In the automobile example the question might be framed, "What rate of closure would prompt you to lift the gas pedal and apply the brakes?". Answer - Depends on how close you are to the thing in front of you. Jim's response was It seems like a fairly simple request on the surface, but too many undefined variables for a simple answer. There is going to be a bit of research involved before this one can be worked out. Richard My ex has a cute "old saying" that she came up with. "Two weeks in the lab will save you three days in the library every time". Richard, If it helps you to see this as a very difficult challenge, then go ahead. I know what the "H" in RAH stands for, but if designing your own circuit from discrete transistors that you've carved out of wood is beyond your interest, then why not look around for a plug 'n' play option? Have you *really* already done that and come up empty handed? I've got a shelf full of catalogs of temperature control hardware. I haven't actually looked for one with a rate alarm option, but since rate is monitored and used by the controller, I don't see why someone wouldn't offer such an alarm as an option. |
![]() If it helps you to see this as a very difficult challenge, then go ahead. I know what the "H" in RAH stands for, but if designing your own circuit from discrete transistors that you've carved out of wood is beyond your interest, then why not look around for a plug 'n' play option? Have you *really* already done that and come up empty handed? I've got a shelf full of catalogs of temperature control hardware. I haven't actually looked for one with a rate alarm option, but since rate is monitored and used by the controller, I don't see why someone wouldn't offer such an alarm as an option. Ok, Smitty. Nope, not at all interested in carving transistors out of wood. Since you have all the catalogs, my suggestion is to "go for it". When you are all done, we can compare "budgets" and judge accordingly. Budgets? First, obviously, would be cost. I'm pretty sure, should he decide to bite, Jim's solution would come in for under 50 bucks. Power budget? We can assume we have a 12 volt DC electrical system. How many amps will you need? Jim probably wouldn't need over 100 mA or so, if that. Weight budget? (Oh Sh*t, not that again!) What say, Jim? 3 or 4 ounces? And then come the electrical issues! It's a thermocouple. Output is in the millivolt range. AND, to monitor RATE of change over a very short time (seconds) we'd have to get down to the microvolt level! To be able to use that, it will have to be scaled up - gain of roughly one million or more? No freakin' way *I* would try that with desecrate (or even wooden) transistors. Again, it's a thermocouple! How do you propose to "interface" to it? Single side ain't gonna get it. You would wind up amplifying the noise as much or more than the signal! Differential low noise high gain op amp seem to be the best solution here. Nope, this simple circuit is way beyond anything this ol' logic mechanic would be able to do. And, not ashamed to admit it, either. So, let's see whatcha got there Smitty? Richard |
Sadism & Machochism? The problem resolves itself to dicking around with a thermocouple probe that puts out millivolts and then picking out the microvolt rise that indicates a rate increase. Can it be done? Sure. Easily? Perhaps. Trivially? Probably not. The second problem, generated by the first, is simulating such a rise and setting the trigger in the simulation. I'm presuming that you don't want to sacrifice an engine to calibrate the rascal. Then the question becomes, what rate do you want to trigger? One degree a second? Ten? A hundred? Or what rise over what time are you interested in? Form the problem and I'll try and come up with a solution. Jim Tie the engine temp to a flashing LED or maybe an audible beep. Rate of flash/beep increases as temp rises. Thing goes crazy as it's warming up, but a button allows you to set the "this is good" steady state. If the temp rises after that, the beeping/flashing starts going again. Maybe the pilot wants to just shut it off again...maybe he decides that danger is clear and present. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Richard Lamb wrote:
I've always wanted to ask Jim if there was a simple circuit that could monitor the EGT and notice the RATE of increase that would indicate a pending problem rather that an already existing one. Maybe blink a light, ring a bell, or apply electric shock as needed? Rich(OUCH)ard That electric shock might be a good last warning that you are about to land wheels up. Just short one of the magnetos to a plate under the pilots seat until the revs increase, or the wheels come down ;-) For those that argue that you might be purposely landing wheels up, I'd add that it would be a good reminder to kill the engine before attempting a belly landing ;-) Don W. |
Minimum Instruments Required? | John A. Landry | Home Built | 5 | October 14th 05 11:27 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Flying on the Cheap - Again | [email protected] | Home Built | 9 | January 23rd 05 04:25 PM |
'They want to ban recreational flying...' | Thomas J. Paladino Jr. | Piloting | 28 | July 22nd 03 07:20 PM |
