Should be easy enough using op-amp comparators with resistors setting up
a 10 or 20 step voltage divider as a reference. For example, if the voltage swing that drives an analog meter goes from 0 volts for the needle at its full down position (high of GS) to 5 volts at its upper most swing (low of GS), the comparators compare the voltage used to move the needle and light a corresponding LED (at 2.5 volts, or half-scale, the green LED would be lit)...Terra produced just such a radio back in the 80s...I think it was called the Tri-Nav C... Scott Fonz wrote: This question is mainly aimed at Jim Weir, but others are more than welcome to give their 2c. With the aero-lectrics column in kitplanes, a GS tester has just been completed. My question. How hard would it be to make a GS indicator, with say LEDs instead of lines and needles. For example, when going down the glideslide, needles centred, you get a Green led in the centre, diverge and get yellow, really off and get red, the universal warning. Rotary encoder with 7 segment leds for OBS. How hard would this project be? (considering the grand scale of the test unit just completed). Obviously not for Primary use, but as a tester for radios, and possibly a back-up unit. Thanks. Just a thought. Rob Australia. |
I'd probably use a 9-step system. Green in the center, then orange, yellow,
blue, and red going up and down. What does the rotary encoder do? Jim "Scott" wrote in message .. . Should be easy enough using op-amp comparators with resistors setting up a 10 or 20 step voltage divider as a reference. For example, if the voltage swing that drives an analog meter goes from 0 volts for the needle at its full down position (high of GS) to 5 volts at its upper most swing (low of GS), the comparators compare the voltage used to move the needle and light a corresponding LED (at 2.5 volts, or half-scale, the green LED would be lit)...Terra produced just such a radio back in the 80s...I think it was called the Tri-Nav C... Scott Fonz wrote: This question is mainly aimed at Jim Weir, but others are more than welcome to give their 2c. With the aero-lectrics column in kitplanes, a GS tester has just been completed. My question. How hard would it be to make a GS indicator, with say LEDs instead of lines and needles. For example, when going down the glideslide, needles centred, you get a Green led in the centre, diverge and get yellow, really off and get red, the universal warning. Rotary encoder with 7 segment leds for OBS. How hard would this project be? (considering the grand scale of the test unit just completed). Obviously not for Primary use, but as a tester for radios, and possibly a back-up unit. Thanks. Just a thought. Rob Australia. |
The rotary encoder would be used, with some sort of position feedback to
change the obs setting if in the VOR mode, in the GS mode it does nothing. Your thoughts on the 9 step system are exactly what I was thinking of, but you were able to explain it clearly. Thoughts on how it would work? "RST Engineering" wrote in message .. . I'd probably use a 9-step system. Green in the center, then orange, yellow, blue, and red going up and down. What does the rotary encoder do? Jim "Scott" wrote in message .. . Should be easy enough using op-amp comparators with resistors setting up a 10 or 20 step voltage divider as a reference. For example, if the voltage swing that drives an analog meter goes from 0 volts for the needle at its full down position (high of GS) to 5 volts at its upper most swing (low of GS), the comparators compare the voltage used to move the needle and light a corresponding LED (at 2.5 volts, or half-scale, the green LED would be lit)...Terra produced just such a radio back in the 80s...I think it was called the Tri-Nav C... Scott Fonz wrote: This question is mainly aimed at Jim Weir, but others are more than welcome to give their 2c. With the aero-lectrics column in kitplanes, a GS tester has just been completed. My question. How hard would it be to make a GS indicator, with say LEDs instead of lines and needles. For example, when going down the glideslide, needles centred, you get a Green led in the centre, diverge and get yellow, really off and get red, the universal warning. Rotary encoder with 7 segment leds for OBS. How hard would this project be? (considering the grand scale of the test unit just completed). Obviously not for Primary use, but as a tester for radios, and possibly a back-up unit. Thanks. Just a thought. Rob Australia. |
Weir W-2 Gyro | [email protected] | Home Built | 2 | October 29th 05 11:12 PM |
RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 01:19 AM |
Jim Weir and radio racks | Matthew M. Jurotich | Home Built | 4 | November 13th 03 03:51 AM |
B is for Governor candidate Jim Weir | Montblack | Piloting | 17 | August 19th 03 04:35 AM |
B is for Governor candidate Jim Weir | Montblack | Owning | 9 | August 13th 03 12:45 AM |
