Live for one winter in Sacramento and you won't ask that question. Near
sunrise most pilot have ATIS continuously tuned monitoring the dew point second by second. If the spread is right, the moment the first bit of sun touches the earth the fog forms, sometimes going from CAVU to 1/2 vis in just minutes. -Robert |
Why does sun touching the earth form fog? I've seen it happen, but I've
never understood why. "Robert M. Gary" wrote in message ups.com... Live for one winter in Sacramento and you won't ask that question. Near sunrise most pilot have ATIS continuously tuned monitoring the dew point second by second. If the spread is right, the moment the first bit of sun touches the earth the fog forms, sometimes going from CAVU to 1/2 vis in just minutes. -Robert |
never understood why. I"m sure if I get this wrong someone on the list will correct me. In Sacramento we receive two types of fog... 1) Advection Fog. This gets blown up from the Bay Area and usually forms late at night and will often stay around until mid-day. 2) Radition Fog. This is the stuff that forms out of the blue. I believe what happens is that the ground is already very moist but the moisture is held in the ground. Once the sun hits it the water on the ground warms releasing the moisture into the cool calm air. Sometimes you'll drive by a field and see the field totally engulfed in fog while the road you are on is clear. Unfortunately airports seem to be composed of a lot of grass and dirt areas. Perhaps if you paved the entire airport boundry you'd have less fog. I know some airports have used helicopter to just fly around and blow the fog around.This fog forms very, very fast at dawn. However, I've never been able to predict it. Sometimes given the same temp/dew points and winds fog will form, other times it will not. I'm not sure what all the factors are. |
It causes some vertical motion which stirs the air a little,
casing the fog to form. "Steve Foley" wrote in message news:EkoNf.1255$v34.1168@trndny02... | Why does sun touching the earth form fog? I've seen it happen, but I've | never understood why. | "Robert M. Gary" wrote in message | ups.com... | Live for one winter in Sacramento and you won't ask that question. Near | sunrise most pilot have ATIS continuously tuned monitoring the dew | point second by second. If the spread is right, the moment the first | bit of sun touches the earth the fog forms, sometimes going from CAVU | to 1/2 vis in just minutes. | | -Robert | | | |
![]() "Jim Macklin" wrote in message news:%mqNf.107786$QW2.7653@dukeread08... It causes some vertical motion which stirs the air a little, casing the fog to form. Yes! The very coldest air at that time of morning is right at the surface of the earth. As it starts to mix with air above it, it cools a whole layer of 50 or a hundred feet or so, instead of just the thin surface layer. If the average moisture content through that layer is such that the cooling drops the temperature down to the average dew-point, bingo. If you watch weather reports carefully, you will find that in those clear-morning situations, the lowest temperature occurs *after* sunrise, when you would have expected that warming is started. But when this mixing starts, that coldest air at the surface (as part of the slight turbulence) reaches up to the 1 metre level where the "official" thermometers are kept. If you check a weather observing site which observes "grass" temperatures, such as an experimental farm or the like, you will see just how great this temperature difference between the grass level and the official 1 meter level can be at sunrise... exceeding 5 degrees Celsius in clear-sky cases. |
That is also why it takes just a slight breeze to get thick
fog. No wind at all, no fog, stronger winds push the cloud bases up a few hundred feet and IFR becomes possible when ILS minimums are reached. -- James H. Macklin ATP,CFI,A&P -- The people think the Constitution protects their rights; But government sees it as an obstacle to be overcome. some support http://www.usdoj.gov/olc/secondamendment2.htm See http://www.fija.org/ more about your rights and duties. "Icebound" wrote in message ... | | "Jim Macklin" wrote in message | news:%mqNf.107786$QW2.7653@dukeread08... | It causes some vertical motion which stirs the air a little, | casing the fog to form. | | | | | | Yes! | | The very coldest air at that time of morning is right at the surface of the | earth. As it starts to mix with air above it, it cools a whole layer of 50 | or a hundred feet or so, instead of just the thin surface layer. If the | average moisture content through that layer is such that the cooling drops | the temperature down to the average dew-point, bingo. | | If you watch weather reports carefully, you will find that in those | clear-morning situations, the lowest temperature occurs *after* sunrise, | when you would have expected that warming is started. But when this mixing | starts, that coldest air at the surface (as part of the slight turbulence) | reaches up to the 1 metre level where the "official" thermometers are kept. | | If you check a weather observing site which observes "grass" temperatures, | such as an experimental farm or the like, you will see just how great this | temperature difference between the grass level and the official 1 meter | level can be at sunrise... exceeding 5 degrees Celsius in clear-sky cases. | | | | | | | | | |
![]() wrote in message oups.com... HI, Where does a pilot use the dew-point? Why is the volmet transmiting this info? Thanks frank The dew point is also used to forecast the expected overnight low temperature. This will be used most by pilots who may be concerned about their gardens and whether they need to be covered to protect from frost. Happy landings, |
Crouch Strap story | Ed Byars | Soaring | 43 | September 23rd 13 05:43 PM |
Adding a lifting point. | [email protected] | Home Built | 1 | March 8th 05 03:05 PM |
A Question For Real Airline Pilots | Blue | Simulators | 34 | September 6th 04 01:55 AM |
Altitude loss for 5h Duration Flight | nyffeler | Soaring | 9 | August 28th 04 11:12 AM |
flight training - 100nm night flight requirement | Jonathan | Piloting | 36 | May 11th 04 07:34 PM |
