#11
----------------------much snipping------------- If I'm not mistaken, Hughes once built some kinda giant tip-thrust powered test-freak that had a rotor speed of about 16 rpm. I've seen the videos, but I can't recall the name. Fairchild-Hiller once built something like that, supposedly with ram jets in the tips, and Hughes may have as well; although I am fairly sure that the rotor speed was within the normal range for helicopters. There was also a propane fueled pulse jet powered single blade helicopter of the strap-onto-the-pilot variety several years ago. ( I even had a "blurb" about it--and a related APU for gliders--which may still be buried among other books and catalogs.) Although I don't know if it ever flew out of tether... Peter P.S.: As to the original post: the pilot shops at most airports have passable texts to introduce the theory of helicopters, and a lot of accomplished helicopter pilots and mechanics used to hang around on "rec.aviation.rotorcraft: so that lurking over there could pay dividends... |
wright1902glider wrote:
Now here's a simple 19th Century way to prove the point. Attach a length of yarn to the "lower" surface of a slow-flying plane. Watch the yarn and see what direction it takes in flight. Is it straight back? Or is it down? If air is indeed being forced downward by the wing, shouldn't we be able to see the results in the yarn? Harry Thank you, Harry! |
"Attach a length of yarn to the "lower" surface of a slow-flying plane.
Watch the yarn" Is this why they invented wing walking? How do I do that on a low wing monoplane? Colin |
This pushes and pulls on the rotor-blade control horns,
constantly changing the pitch of the blade as it flys around in a circle. If you tilt the dinner plates forward, the blade flys at a lower AOA in the front 1/2 of the rotor disk than it does at the back 1/2. Since its producing more lift in the back 1/2 than in the front 1/2, the blade flies higher in back. Stay with me here. As the blade flies higher, its coning angle relative to the rotor head increases to a greater angle than it does in the forward 1/2 of the rotor disk.. Therefore, its line of thrust relative to the fuselage is not vertical, but is actually inclined forward. Except the swash plate is not inclined forward in forward flight. It's inclined to the right in forward flight, if the rotor turns counterclockwise as seen from above, as in most American 'copters. The rotor is a gyroscope, and trying to tilt one edge of it will result instead in tilting the edge 90 degrees away in the direction of rotation, like any other gyro. The rotor blades reach their maximum pitch on the left side of the machine, and the blades reach their maximum flap at the rear, tilting the disc forward. The advancing blade on the right has minimum pitch and the front of the disc is lowest.This is a happy coincidence, since we also need a lot more AOA on the retreating blade to partly make up for its much lower airspeed through the air compared to the advancing blade on the right. Assymetrical lift has to be dealt with or the machine will roll over as soon as it move forward, so the retreating blade's higher pitched AOA, the blade's small downward flap approaching the retreating side and rising flap approaching the advancing side also contributes to AOA changes, and the lead/lag hinges on many rotors allow the blades to accellerate on the retrating side and decellerate on the advancing side at and therefore reduce some of the airspeed difference. Symmetrical airfoils are used to minimize vibration caused by center of pressure changes with AOA changes. Helicopters are a lot more complex than they seem. Dan |
The 300 hp in the helicopter is moving it's wing fast enough to lift the
Helo. The fixed wing engine is also moving it's wing fast enough to lift the aircraft. The Helicopter itself need not move forward, so the lift appears vertical, but the wing is indeed climbing at a shallow angle, just like the fixed wing. Al "Don W" wrote in message . net... Can someone explain to me why 300HP applied to a large rotor at ~700 RPM is enough to lift a 2000lb helicopter straight up, but the same 300HP applied to a smaller diameter propellor at ~2600 RPM can not even come close to allowing a 2000 LB airplane to climb vertically? This is really bugging me. BTW, does anyone have any idea what the thrust produced by the propellor of the hypothetical 300 HP (say LYC-IO540 powered) airplane would be? Obviously the thrust produced by the 300HP helicopter exceeds 2000 LBs. TIA, Don W. |
ELIPPSE wrote:
Well, the way I hears it, the low pressure on the wing is produced by the Coanda effect as air travels up and over the wing, not because of a change of velocity.The velocity change hypothesis has been disproven over and over! The mass of air displaced downward is the result (read: reaction) to the air having clung-to and been moved around the surface by the Coanda effect. Lift is caused by a pressure difference, not the downwash. There is no such force as suction, and downwash doesn't generate lift. http://jef.raskincenter.org/publishe...da_effect.html scroll down to OTHER PARADOXES |
Alan Baker wrote: Don W wrote: Can someone explain to me why 300HP applied to a large rotor at ~700 RPM is enough to lift a 2000lb helicopter straight up, but the same 300HP applied to a smaller diameter propellor at ~2600 RPM can not even come close to allowing a 2000 LB airplane to climb vertically? Don W. snip So if you go from rotor moving x mass per second at y speed to a propellor moving x/2 mass per second at 2y speed, then your power goes down by half from the change in mass, but *up* by four from the change in speed. IOW, move half the mass to achieve the same force and you need to use twice the power. Does that help? Yes Alan, it does. I had just not thought of it that way. Now that you point it out, it makes perfect sense. This is what I think you said: force = d (mv)/dt = force = d (m)/dt * d(v)/dt = force = d(m)/dt * (v1-v0) In English: force is equal to mass flow rate times the difference in velocity before and after the propellor. Ek= 1/2 (mv^2) -and- Power = d(Ek)/dt = Power = d(m)/dt * (v1-v0)^2 In English: Power is the rate of change of the kinetic energy of the airflow which is equal to the mass airflow times the square of the difference in velocity before and after the propellor. Is that correct? If so, it says that for fuel efficiency you want as big a prop as you can fit turning slow. That also makes sense because the parasitic drag on the prop goes up as the square of the blade velocity as well. big grin I think something fundamental just just clicked. Don W. |
Peter Dohm wrote: "Don W" wrote in message . net... Can someone explain to me why 300HP applied to a large rotor at ~700 RPM is enough to lift a 2000lb helicopter straight up, but the same 300HP applied to a smaller diameter propellor at ~2600 RPM can not even come close to allowing a 2000 LB airplane to climb vertically? This is really bugging me. BTW, does anyone have any idea what the thrust produced by the propellor of the hypothetical 300 HP (say LYC-IO540 powered) airplane would be? Obviously the thrust produced by the 300HP helicopter exceeds 2000 LBs. TIA, Don W. I am not a helicopter guy, so please don't expect my to carry this thread very far; but I'll try at the most basic level. Lift as generated by throwing air downward in order to maintain the altitude, or the constant rate of ascent or descent, of an object is based upon a momentum equation--rather than an energy equation. Therefore, throwing twice as much air downward half as fast will support the same weight; but will require about half as much energy per unit time, or about one half the horsepower. Remember that horsepower is a measure of energy, or work, per unit of time. This makes sense to me now. OTOH, in the case of an airplane propeller, we need to make the energy equation work--while the wings deal with the momentum equation. We can choose a wingspan appropriate for the intended weight and cruising speed and a wing area to meet our stall speed requirements, determine the expected drag in cruise, choose a propeller disk area and number of blades appropriate for reasonable efficiency in cruise, and match the result to an engine, and possibly a PRSU since the propeller disk area determines the diameter and the maximum RPM. Finally, determine that the available power can supply sufficient thrust for take-off and climb. Traditionally, small airplanes produce a maximum static thrust on the order of one fifth of their weight when tied in place, and much less in cruise. The propeller, of course, constantly transitions into new and undisturbed air and its efficiency improves from zero at the start of the take-off roll to an acceptable figure in cruise. Nit picking here, but the propellor is actually doing a lot of work even when the aircraft is not moving. It just does not translate into useful work on the airplane. You are thinking of the work as thrust * velocity (airplane) which is correct from the viewpoint of the airplane, but not the system. The prop is moving plenty of air, dust, leaves etc. although that does not help you get where you are going. One size does not fit all. BTW, a 700 rpm rotor is pretty small and may be really inefficient--even by helicopter standards! I hope this helps. Peter Yes it does. Thanks. Don W. |
Hi Colin,
I cant remember what the max rotor rpm on the R22 Beta is although I have a few hours in them. I just make sure that both guages stay in the green arc and that little light and the annoying horn don't come on ;-). Don W. COLIN LAMB wrote: BTW, a 700 rpm rotor is pretty small and may be really inefficient--even by helicopter standards! The Schweizer 300 (formerly Hughes 269C) has a rotor rpm power on of 442 to 471 rpm. Power off range is 390 to 504 rpm. Esceed these limits and you are quite likely to break something. The Schweizer has 190 hp and gross weight is 2050 lbs. Colin |
| Thread Tools | |
| Display Modes | |
| Propellors for sale | Jean-Paul Roy | General Aviation | 0 | July 15th 04 03:33 PM |
| Propellors for sale | Jean-Paul Roy | Owning | 0 | July 15th 04 03:32 PM |
| Inflatable Rotors (Flying Car?) | Ken Sandyeggo | Home Built | 13 | August 6th 03 07:37 AM |
| Inflatable Rotors (Flying Car?) | Ken Sandyeggo | Rotorcraft | 2 | August 6th 03 07:37 AM |
| Inflatable Rotors (Flying Car?) | Mark Hickey | Rotorcraft | 4 | August 1st 03 06:20 AM |
