http://www.naco.faa.gov/d-tpp/0405/09743IL33.PDF
I haven't come across an approach with two separate missed approach procedures before. Is this even remotely common? I think I'll add this to my instrument students' training regiment due to some additional interesting features- teardrop course reversal, intersection identification using ndb bearings (not using DME), and a lot of stuff to brief. Some of the approaches down here in central VA are pretty boring. |
![]() Brad Z wrote: http://www.naco.faa.gov/d-tpp/0405/09743IL33.PDF I haven't come across an approach with two separate missed approach procedures before. Is this even remotely common? I think I'll add this to my instrument students' training regiment due to some additional interesting features- teardrop course reversal, intersection identification using ndb bearings (not using DME), and a lot of stuff to brief. Some of the approaches down here in central VA are pretty boring. There are lots of IAPs with alternate, non-radar missed approach procedures. But, the alternate procedure is normally provided only to the controlling ATC facility. You've come across one of the first, if not the first, IAPs to include the text of the alternate missed approach procedure on the chart. There is some resistance to charting the alternate, even just textually, so this concept may or may not take hold. |
FAA has been adding alternate missed approach procedures to ILS
approaches to allow the ILS procedure to still be flyable even when the VOR or VORTAC used in the procedure is INOP. They don't normally publish this on the procedure though. I like it though, because then a NOTAM doesn't need to be sent listing the alternate missed approach procedure when BRV is INOP. If there are a lot of military TACAN equipped aircraft that use this particular procedure, then having the other missed approach procedure published is required, since TACAN aircraft cannot hold directly over a VORTAC or TACAN (unless they also have a VOR). In that case, it would normally be published as shown on this procedure at Chippewa MI; http://www.naco.faa.gov/d-tpp/0405/00810I16.PDF Brad Z wrote: http://www.naco.faa.gov/d-tpp/0405/09743IL33.PDF I haven't come across an approach with two separate missed approach procedures before. Is this even remotely common? I think I'll add this to my instrument students' training regiment due to some additional interesting features- teardrop course reversal, intersection identification using ndb bearings (not using DME), and a lot of stuff to brief. Some of the approaches down here in central VA are pretty boring. |
J Haggerty wrote:
TACAN aircraft cannot hold directly over a VORTAC or TACAN (unless they also have a VOR). Why not? |
![]() Roy Smith wrote: J Haggerty wrote: TACAN aircraft cannot hold directly over a VORTAC or TACAN (unless they also have a VOR). Why not? He's right in the case of a TACAN, wrong in the case of a VORTAC. |
![]() wrote in message ... Roy Smith wrote: J Haggerty wrote: TACAN aircraft cannot hold directly over a VORTAC or TACAN (unless they also have a VOR). Why not? He's right in the case of a TACAN, wrong in the case of a VORTAC. Why? What difference does it make to a TACAN-only aircraft if the navaid is a TACAN or a VORTAC? |
![]() "Steven P. McNicoll" wrote: wrote in message ... Roy Smith wrote: J Haggerty wrote: TACAN aircraft cannot hold directly over a VORTAC or TACAN (unless they also have a VOR). Why not? He's right in the case of a TACAN, wrong in the case of a VORTAC. Why? What difference does it make to a TACAN-only aircraft if the navaid is a TACAN or a VORTAC? I misread it; I thought it was a VOR aircraft. |
![]() Roy Smith wrote: In article , wrote: "Steven P. McNicoll" wrote: wrote in message ... Roy Smith wrote: J Haggerty wrote: TACAN aircraft cannot hold directly over a VORTAC or TACAN (unless they also have a VOR). Why not? He's right in the case of a TACAN, wrong in the case of a VORTAC. Why? What difference does it make to a TACAN-only aircraft if the navaid is a TACAN or a VORTAC? I misread it; I thought it was a VOR aircraft. OK guys, now that we've established that, let me repeat my original question, which seems to have gotten lost in the shuffle... Why can't a TACAN-only aircraft hold directly over a TACAN? Never used one. I have a vague recollection it has something to do with too large of a zone of ambiuity. Perhaps some Naval flyer can give the specifics. |
![]() "Roy Smith" wrote in message ... OK guys, now that we've established that, let me repeat my original question, which seems to have gotten lost in the shuffle... Why can't a TACAN-only aircraft hold directly over a TACAN? The short answer is because it's not permitted, see the note following subparagraph d. below. The long answer? The technical reason behind the restriction? Beats the hell outta me. FAA Order 7110.65P Air Traffic Control Chapter 4. IFR Section 1. NAVAID Use Limitations 4-1-5. FIX USE Request aircraft position reports only over fixes shown on charts used for the altitude being flown, except as follows: NOTE- Waypoints filed in random RNAV routes automatically become compulsory reporting points for the flight unless otherwise advised by ATC. a. Unless the pilot requests otherwise, use only those fixes shown on high altitude en route charts, high altitude instrument approach procedures charts, and DP charts when clearing military turbojet single-piloted aircraft. b. Except for military single-piloted turbojet aircraft, unpublished fixes may be used if the name of the NAVAID and, if appropriate, the radial/course/azimuth and frequency/channel are given to the pilot. An unpublished fix is defined as one approved and planned for publication which is not yet depicted on the charts or one which is used in accord with the following: REFERENCE- FAAO 7130.3, Holding Pattern Criteria. 1. Unpublished fixes are formed by the en route radial and either a DME distance from the same NAVAID or an intersecting radial from an off-route VOR/VORTAC/TACAN. DME shall be used in lieu of off-route radials, whenever possible. 2. Except where known signal coverage restrictions exist, an unpublished fix may be used for ATC purposes if its location does not exceed NAVAID altitude and distance limitation, and when off-route radials are used, the angle of divergence meets the criteria prescribed below. NOTE- Unpublished fixes should not negate the normal use of published intersections. Frequent routine use of an unpublished fix would LEFT establishing a fix. REFERENCE- FAAO 7110.65, Altitude and Distance Limitations, Para 4-1-1. 3. Do not hold aircraft at unpublished fixes below the lowest assignable altitude dictated by terrain clearance for the appropriate holding pattern airspace area (template) regardless of the MEA for the route being flown. 4. When the unpublished fix is located on an off-route radial and the radial providing course guidance, it shall be used consistent with the following divergence angles: (a) When holding operations are involved with respect to subparas (b) and (c) below, the angle of divergence shall be at least 45 degrees. (b) When both NAVAIDs involved are located within 30 NM of the unpublished fix, the minimum divergence angle is 30 degrees. (c) When the unpublished fix is located over 30 NM from the NAVAID generating the off-course radial, the minimum divergence angle shall increase 1 degree per NM up to 45 NM; e.g., 45 NM would require 45 degrees. (d) When the unpublished fix is located beyond 45 NM from the NAVAID generating the off-course radial, the minimum divergence angle shall increase 1/2 degree per NM; e.g., 130 NM would require 88 degrees. c. Fixes contained in the route description of MTRs are considered filed fixes. d. TACAN-only aircraft (type suffix M, N, or P) possess TACAN with DME, but no VOR or LF navigation system capability. Assign fixes based on TACAN or VORTAC facilities only. NOTE- TACAN-only aircraft can never be held overhead the NAVAID, be it TACAN or VORTAC. e. DME fixes shall not be established within the no-course signal zone of the NAVAID from which inbound holding course information would be derived. REFERENCE- FAAO 7110.65, NAVAID Fixes, Para 2-5-3. FAAO 7110.65, Methods, Para 5-6-2. |
Approach Question- Published Missed Can't be flown? | Brad Z | Instrument Flight Rules | 8 | May 6th 04 04:19 AM |
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? | S. Ramirez | Instrument Flight Rules | 17 | April 2nd 04 11:13 AM |
Why an NDB approach with a miss to an intersection? | Ben Jackson | Instrument Flight Rules | 10 | March 25th 04 03:53 AM |
Which of these approaches is loggable? | Paul Tomblin | Instrument Flight Rules | 26 | August 16th 03 05:22 PM |
IR checkride story! | Guy Elden Jr. | Instrument Flight Rules | 16 | August 1st 03 09:03 PM |
