I have the 720A and find it very sensitive to voltage. We run ours using a
12v battery and have no problem as long as the voltage stays above the 11.2-12v range. When the voltage does drop much below 11.2 the radio starts sounding bad to others. A weak, older battery will give you nothing but headaches with this radio. Doug "Don Byrer" wrote in message ... I have a Terra 720 and the manual states that the radio wants 13.75 VDC. Ironically, I don't talk on the radio much because the many conversations going on are distracting to me so I leave it off most of the time. On a typical flight, it sees a 25% duty cycle. But if I need it, I want it to work well, thus the 14 VDC. Overkill? What do you think? "14 volt" aircraft have a 12 volt battery. The alternator makes ~14V (nominal 13.8V); the alternator voltage must be higher than battery voltage for the battery to charge. Methinks the radio should work acceptably on 12V, probably even 11-ish...but I do not have experience with the Terra 720. --Don Don Byrer Commercial Pilot / CFI Student Electronics Technician, RADAR/Data/Comm @ CLE Amateur Radio KJ5KB "I have slipped the surly bonds of earth; now if I can just land without bending the gear..." "I know what it sounds like....when doves cry" (Bird Strike 8/29/05) |
Battery Question | [email protected] | Soaring | 19 | September 15th 05 01:38 AM |
New Battery -- thanks for the recommendation | Jay Honeck | Owning | 28 | July 10th 05 07:20 PM |
RG Battery Charger by Jim Weir in Kitplanes | Kevin O'Brien | Home Built | 4 | January 6th 05 01:19 AM |
