Wallace,
Yes, that's the one. First, let me say that I don't represent my club, so anything I say in this thread is my thought alone. There are people smart about winching in our club, I'm just trying to learn, and maybe contribute something to the group. The first thing I heard about this winch was that we'd remove the cable and replace it with something like the 'Plasma' on the other drum. Do you know how long those lines are? I was thinking about the retreive winch, and it seems to me that our old winch will be serious overkill, if it would even work. My gut feel is that something like a snowmobile engine with a centrifugal clutch would work, if that's enough power. What would you use for a drum? I was also thinking about using the parts of some small car, like a Geo Metro, which has a 3-cyl front drive system, maybe about 1 liter. I'd modify the differential by welding the spider gears solid, so that you could run with only one axle, and keep the seat and engine as is. Probably take off the roof, and build a lexan protective shield with expanded metal mesh over it to keep the driver and possibly trainee safe from mishaps. Might even be able to use either an original wheel, or some different larger wheel without a tire as the retreive drum. Brakes would already be there, just stop off the lines for the 3 wheels that are removed. Use the foot throttle and brake. Have to make a guillotine, unless there are commercial ones for sale. If I wanted to, I could do something like that myself, I'm pretty sure. I could make it something that I could haul in the back of my (or any) pickup, or tow behind. I'd imagine I could find such a car at a junkyard, wrecked in the rear, but with the front intact. Remove all the parts I don't need, leave all the wiring intact, and hook the steering gear up to rotate the winch within a small range to allow some kind of aiming to keep it pointed at the chute, and maybe act somewhat as a level wind. How much tension do you suppose is required to retreive? Any idea of what kind of speeds would be used? Seems like you would use enough to keep the chute full, and maybe the line in the air as long as possible. Ed |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
