UPDATE #2 -- Headset Noise
I flew the airplane today, and headset noise (alternator whine) has not
been completely eliminated by the resolution of the ground loop through the intercom system, but it has been further reduced to a level where it is just manageable. The "chop chop" or "flutter" electrical noise is still occasionally present in the system when the copilot transmits, and can be heard in the sidetone. HOWEVER, I've now discovered another potential problem. In my quest to inspect ground connections, I pulled the cover on the rear bulkhead to look at the glideslope receiver, strobe power pack, and battery. The master relay is next to the battery, and I nearly burned myself on it after a 30 minute flight--it was that hot. I let it cool down, and ran the airplane for another 5 minutes and it was almost too hot to touch. Logic tells me that heat is created by electrical resistance, and I'm guessing that there shouldn't be enough resistance in the master relay to cause it to get too hot to touch. Is this a failure mode for these relays? Could this be contributing in any way to my electrical noise issues? Thanks, JKG |
Jonathan Goodish wrote:
Logic tells me that heat is created by electrical resistance, and I'm guessing that there shouldn't be enough resistance in the master relay to cause it to get too hot to touch. Is this a failure mode for these relays? Relays can fail such that they get hot. A relay that hot is probably a bad relay. It needs to be fixed or replaced. Could this be contributing in any way to my electrical noise issues? Possibly. |
Jonathan Goodish wrote: HOWEVER, I've now discovered another potential problem. In my quest to inspect ground connections, I pulled the cover on the rear bulkhead to look at the glideslope receiver, strobe power pack, and battery. The master relay is next to the battery, and I nearly burned myself on it after a 30 minute flight--it was that hot. I let it cool down, and ran the airplane for another 5 minutes and it was almost too hot to touch. Since the starter cranking current goes through the master relay, then if the contacts in the master relay develop high resistance, because of the voltage drop, you would not be able to start the engine. The coil in the master relay should pull less than 2A, which would mean that the coil in the relay is dissipating less than 20W. 20W of dissipation will make the case feel too hot to touch... Not all solenoid relays used in aircraft are interchangable. For example, the one that is used as the master in my Cessna is rated for continuous duty, and its coil pulls about an Amp. The starter solenoid, however, is rated only for intermittent duty, and has a much higher coil current (about 3A), probably so it holds in stronger... I have seem people mistakenly replace a continuous duty solenoid with one that is intended to be used as a starting solenoid, and then they wondered why it got so hot.... |
Jonathan Goodish wrote: ....I pulled the cover on the rear bulkhead to look at the glideslope receiver, strobe power pack, and battery. On your alternator whine ground loop problem, check to see how the audio gets out of the glideslope receiver to your audio panel. My Skylane has a rear mounted battery and the Marker Beacon receiver is mounted on an avionics shelf near the battery. When I was chasing my ground loops, one of the biggest ones was that the ARC marker beacon reciever had a case ground referenced audio output, and because of the rear mounted battery, the alternator ripple current flowed along the marker beacon's audio shield. The Marker Beacon has an audio output transformer, but ARC chose to tie one end of the secondary to the MB's case. The solution was to cut the ground strap, and tie that end of the secondary winding to an unsed pin on the connector. That made a true MBhi, MBlow differential floating output, which prevents the airframe ground voltage drop between the fiirewall and the battery from coupling into the audio... |
"mikem" writes:
Not all solenoid relays used in aircraft are interchangable. For example, the one that is used as the master in my Cessna is rated for continuous duty, and its coil pulls about an Amp. The starter solenoid, however, is rated only for intermittent duty, and has a much higher coil current (about 3A), That was my thought as well -- it may be the wrong contactor. Or, it could be bad connections at the, or maybe inside, the contactor. Pull off the output connection, turn on the contactor for 10 min.... can you touch it? -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Look at this diagram:
http://home.utah.edu/~mgm17160/Alter...GroundLoop.jpg That should make this clear. |
In article .com,
"mikem" wrote: Jonathan Goodish wrote: ...I pulled the cover on the rear bulkhead to look at the glideslope receiver, strobe power pack, and battery. On your alternator whine ground loop problem, check to see how the audio gets out of the glideslope receiver to your audio panel. My Skylane has a rear mounted battery and the Marker Beacon receiver is mounted on an avionics shelf near the battery. I checked this yesterday, the case of the glideslope receiver has continuity with ground when it is isolated from the airframe mounting brackett and the antenna is disconnected. JKG |
Jonathan Goodish wrote: In article .com, "mikem" wrote: Jonathan Goodish wrote: ...I pulled the cover on the rear bulkhead to look at the glideslope receiver, strobe power pack, and battery. On your alternator whine ground loop problem, check to see how the audio gets out of the glideslope receiver to your audio panel. My Skylane has a rear mounted battery and the Marker Beacon receiver is mounted on an avionics shelf near the battery. I checked this yesterday, the case of the glideslope receiver has continuity with ground when it is isolated from the airframe mounting brackett and the antenna is disconnected. OK, then the wiring to the GS receiver could well be the source of your ground loop, just like it was in my Skylane. Here is how you can find out: Unplug the cable where it connects to the GS Rx. If there is a ground strap coming out of the plug your just removed from the GS Rx, disconnect it from ground. Insulate the cable end so it cannot touch the airframe, and go fly the airplane. If this reduces or eliminates your ground loop, then either modify the GS Rx, or use a 1:1 500Ohm audio isolation transformer to break the ground loop along the audio from the GSRx to the audio panel at the front of the airplane. Write back if you have questions? |
I flew the airplane today,...The "chop chop" or "flutter" electrical noise is still occasionally present in the system when the copilot transmits, and can be heard in the sidetone. The "chop chop" sounds like RF is getting into the mic audio line, and is causing what hams call "motorboating" (The RF is rectified in the intercom or audio panel input circuits, the resulting DC bias shift causes the low-frequency oscilllation). Solution is to prevent the RF entering the audio line. Put a 100pF RF bypass capacitor at the Mic jack between either: 1). the Mic line terminal to the floating common terminal, or 2). " " " " to airframe ground near the mic jack. Try 1) and 2) to see which accomplishes the desired result. The question is why is RF floating around inside the cockpit. At other things working properly, this is not supposed to happen. A bad Com antenna (bad coax, oxidized BNC connection, bad RF ground between antenna base and airframe) can put a high VSWR onto the Com's transmit coax, and cause radiation off that coax so that it couples into other nearby wiring. Fix the antenna, the VSWR returns to normal, and that gets the RF out out your audio. |
Similar Threads | ||||
Headset Noise | Jonathan Goodish | Owning | 31 | April 19th 06 01:18 PM |
UPDATE -- Headset Noise | Jonathan Goodish | Owning | 7 | April 18th 06 05:43 PM |
Bose Aviation-X Headset Update | Jose | Piloting | 5 | January 24th 06 08:41 PM |
Bose Aviation-X Headset Update | Victor J. Osborne, Jr. | Piloting | 0 | January 24th 06 02:23 AM |
Funny noise update | Peter Duniho | Piloting | 1 | July 1st 04 02:58 PM |
