Flying IFR with Garmins
Old June 17th 04, 04:49 PM
John Bell
Do you define them between two airway points (one behind you) or do
you have to direct to the next fix and just guess how far off the
airway you are?
Robert,
Download my book at www.cockpitgps.com. It's free. Start at GPS Route
Planning, then the Navigation section, then the Route Intercepts Section.
Even though my examples do not use a 296, they are still applicable.
John Bell
Old June 17th 04, 03:33 AM
Newps
"Andrew Sarangan" wrote in message
Why not use a VOR receiver for airway navigation? Using a GPS for airway
navigation kind of seems backwards.
Have you tried it? Putting a flightplan in the GPS and then flying the line
on the moving map eliminates having to worry about crosswind correction.
None of this flying a heading for awhile and seeing how that works. Then
adjusting that heading constantly for constantly changing conditions. With
a GPS you don't need a DG to fly an airway.
Old June 21st 04, 07:37 PM
Andrew Gideon
airway navigation kind of seems backwards.
line on the moving map eliminates having to worry about crosswind
correction. None of this flying a heading for awhile and seeing how that
works. Then
With a GPS you don't need a DG to fly an airway.
Unless you're happy with S turning your way along, this is only true if
you've the GPS providing track information. A 172S I used to fly had an
MFD plugged into the GPS. It provided not just the flight plan on the map,
but also a line indicating the path the flight would take if no changes
were made. Put that line over the course line, and details like heading,
deviation, and such become pretty trivial.
Alternatively, just match desired track with actual track (starting from a
zero OBS deflection, of course {8^).
That damned MFD really spoiled me, in fact. I was S turning for a while
when I stopped flying that airplane laugh.
On the 430s I fly now, there are only four fields in which information can
be displayed. I use "next waypoint", distance to next waypoint", "desired
track", and "ground speed". I had to give up "actual track", sadly.
- Andrew
Old June 20th 04, 09:19 AM
Julian Scarfe
"Robert M. Gary" wrote in message
om...
And you don't have to try to figure out the correction angle while
trying to stay on the airway while you are getting bounced around in
the clouds in busy airspace.
There's nothing to stop you using the VOR for course guidance but using the
GPS track readout to ensure that your track matches the VOR radial. Forgive
me if that's very obvious, but I'm always surprised at how many pilots don't
use that aspect of the GPS to take the hard work out of tracking
conventional navaids (particularly on the ILS).
Julian Scarfe
Old June 21st 04, 06:12 AM
John Harper
I agree that this is a great technique. In fact I never use NAV mode on
my autopilot, I just tweak the heading until the track matches what it
should
be (and keep an eye on it obviously). Much better than the autopilot
zigzagging its way down the airways.
John
"Julian Scarfe" wrote in message
news:yMbBc.15$9D3.5@newsfe6-win...
om...
Forgive
don't
Julian Scarfe
Old June 21st 04, 06:51 AM
Robert M. Gary
How do you do that with the 296? How do you program in a radial to fly
to? I don't even see radials on the VORs when I look at it. I haven't
been able to find anything on this in the manual.
Julian Scarfe
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 02:58 PM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 06:07 PM
Flying Wing Design workshop in july 04 mat Redsell Home Built 1 May 5th 04 02:53 PM
restarting instrument flying Matthew S. Whiting Instrument Flight Rules 13 November 21st 03 02:04 PM
seeking info from NW Ontario/ Upper Midwest Pilots flying intoAtikokan David Megginson Instrument Flight Rules 0 July 9th 03 04:04 PM
