SeeYou Airspace problem
Old April 25th 06, 10:25 PM posted to rec.aviation.soaring
Default SeeYou Airspace problem
When I select airspace B or C my screen turns completely
red or Blue... Class D airspace is ok but class B,
C turns the screen red or blue and only the turnpoints
are visible... Fl is set to FL200...Version 3.5a I
tried everthing...
LV
Gregg Leslie
Old April 26th 06, 05:31 AM posted to rec.aviation.soaring
Hi Gregg,
Are you referring to SeeYou or SeeYou Mobile?
I recently found that I needed to uncheck the checkbox labeled "use colors
as defined in file" with the latest version of the airspace file from
SeeYou. You can find the checkbox in the Tools/Airspace window.
In the same screen you can define whether the airspace types are filled or
just outlined. I prefer to have the outlined only.
Let me know if that doesn't solve your problem.
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
"Gregg Leslie" wrote in message
tried everthing...
LV
Gregg Leslie
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 12:51 AM
Negative XPDR - under the outer ring of Class C bcjames Piloting 8 August 30th 04 11:49 PM
Two airspace classes for one airspace? (KOQU) John R Piloting 8 June 30th 04 04:46 AM
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) Snowbird Home Built 78 December 3rd 03 09:10 PM
