MontJet update
Old April 28th 06, 09:08 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default MontJet update
"Montblack" wrote in message
PROBLEM down below.
Single place, single engine MontJet:
[Based on the Spectrum 33 numbers]
Wing .........................45 lbs
Fuselage ..................45 lbs
Jet engine ..............200 lbs?
Everything else ........60 lbs
MontJet Empty Wt .350 lbs
(Double the Empty Weight of the Cri-Cri)
I see ur problem, and I'm shocked you didn't catch it!
That 200 pounds for engines is way too high! You should have substituted a
couple of Rotax engines, for those.
g
What comes around, goes around. ;-))
Jim in NC
MontJet update Montblack Piloting 18 May 1st 06 10:54 PM
New info on MontJet numbers Montblack Home Built 2 April 24th 06 09:41 PM
New info on MontJet numbers Montblack Piloting 2 April 24th 06 09:41 PM
Latest Windows vulnerability UPDATE john smith Piloting 1 January 6th 06 08:43 PM
8th Anniversary : Kiwi Aircraft Images Update Phillip Treweek Military Aviation 0 August 13th 04 01:45 AM
