MontJet update
Old April 28th 06, 10:07 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default MontJet update
("Morgans" wrote)
That 200 pounds for engines is way too high! You should have substituted
a couple of Rotax engines, for those.
VL"J" ...Hello. They're not talking about "Jets" in the carb! g
What comes around, goes around. ;-))
I thought that was your issue with the Rotax all along - that it doesn't
always come back around. chuckle
Anyone out there with a PROVEN jet engine, with a fuel burn under
(Spectrum's per engine average)27 gph, that puts out 800-1,200 pound-thrust,
and weighs under 200 lbs?
15-20 gph* would be nice.
(* For 2 to 4 hour trips at 35,000-45,000 feet. Shorter trips will burn
more)
Otherwise: Williams FJ33-4A [1,568 pound-thrust] @ 290 lbs it is.
I feel so much like the Eclipse team, right now, it's scary! :-)
http://www.spectrum.aero/downloads/competitive_analysis.pdf
Competitive analysis Spectrum 33 vs. other Jets.
2 engines and... "4 passengers, NBAA IFR Reserves"
[300 nm]
617 lbs. is 84.1 gal ....0 hr+53 (53 min) = 99.6 gph/2 engines
[600 nm]
688 lbs. is 98.3 gal ...1 hr+41 (101 min) = 58.2 gph/2 engines
[1000 nm]
1,096 lbs. is 156.6 gal ....2 hr+50 (170 min) = 55.2 gph/2 engines
[1,600 nm]
1,647 lbs. is 235.3 gal ....4 hr+35 (275 min) = 51.6 gph/2 engines
Team MontJet
Old April 29th 06, 10:29 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
and just for "fun", how much would be the cost of a FJ33 ?
MontJet update Montblack Piloting 18 May 1st 06 10:54 PM
New info on MontJet numbers Montblack Home Built 2 April 24th 06 09:41 PM
New info on MontJet numbers Montblack Piloting 2 April 24th 06 09:41 PM
Latest Windows vulnerability UPDATE john smith Piloting 1 January 6th 06 08:43 PM
8th Anniversary : Kiwi Aircraft Images Update Phillip Treweek Military Aviation 0 August 13th 04 01:45 AM
