Have you created anything "home-made" for your plane? (or a low cost alternative?)
Old April 29th 06, 03:25 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
Default Have you created anything "home-made" for your plane? (or a low cost alternative?)
On Sun, 9 Apr 2006 09:06:54 -0700, "RST Engineering"
Instead of aluminum, use PVC water pipe. It's lighter yet and can be worked
with simple tools.
And you glue the edges or run a bolt thru both diameters? maybe a 1/2"
above ground level? - Mike
Have you created anything "home-made" for your plane? (or a low cost alternative?) Andy Piloting 69 April 29th 06 03:25 PM
Washington DC airspace closing for good? tony roberts Piloting 153 August 11th 05 12:56 AM
Boeing Boondoggle Larry Dighera Military Aviation 77 September 15th 04 02:39 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 12:17 AM
