Have not flown the ASW 24B so I cannot compare!
Have flown the DG303Acro, DG 808S and ASW 28-18E Flying a ASW20B in comps in November Found this for you. http://www.dg-flugzeugbau.de/tm-300-e.html Alexander Schleicher ASW 24 - Background information on the original - The ASW 24 was designed by Schleicher's Gerhard Waibel, with Delft University professor Loek Boermans undertaking the role of aerodynamicist. The prototype made its first flight in 1987, having entered serial production later the same year. It nominally remained in production until 2000, although only a score were built in the mid-to-late nineties. It entailed a large development effort, as it was a complete departure from the preceding ASW 19 and pioneered several successful innovations. The fuselage, airfoils, wings and empennage were completely new, as well as many systems, e.g. the electrical ballast management. The structure employed a large amount of the then still exotic carbon fibre. The OSTIV Award-winning safety cockpit made use of an organic shape, tall sidewalls, crumple zones and exotic aramid fibres for crash protection. A large wheel with a disc brake and a large canopy with excellent visibility were other strong points of the type. The ASW 24 was moderately successful in competitions. It won a single World Championship in 2001, fourteen years after its market launch. As the contemporary LS7, the ASW 24 overstretched the technology available at the time: it has excellent performance in the cruise but less so in the slow flight range. The higher-than-usual thermalling speed revealed itself a disadvantage in the typical competition gaggles, and its performance degrades significantly when subject to turbulence, rain or wing contamination. According to World Champion Sarah Steinberg, it needs to be always proactively flown in thermals, thus imposing a higher workload upon the pilot. Notwithstanding, the aesthetically pleasing ASW 24 is a comfortable, safe and pleasant sailplane with high cross-country performance that remains competitive up to national championship level in most countries. The fuselage of the ASW 24 was the basis, with small modifications, for the subsequent ASW 27, ASW 28 and ASG 29. It was superseded in production by the ASW 28. Technical Data: - Length 6.55 m - Height 1.3 m - Wingspan 15 m - Wing area 10.00 m² - Empty weight ca. 230 kg - Water ballast 155 kg (ASW 24) 160 kg (ASW 24B) - Maximum take off 500 kg - Wing loading ca. 31.0 - 50.0 kg/m² - Minimum sink rate ca. 0.55 m/s at 31 kg/m² - Best glide ratio ca. 43 (ASW 24) ca. 44 (ASW 24B) |
FS: DG 303 Acro - Perfect!!! | [email protected] | Soaring | 3 | June 23rd 05 02:01 PM |
Acro Sport II | Al MacDonald | Aerobatics | 1 | September 1st 04 06:38 PM |
WANTED: Left wing G103 Acro II [US] | F.L. Whiteley | Soaring | 0 | July 20th 04 03:15 PM |
Mid-Air at Turf, Acro boxes etc | Rick Brown | Soaring | 0 | January 24th 04 04:51 AM |
Turf Soaring Mid-Air, Acro Boxes, Etc | Rick Brown | Soaring | 0 | January 23rd 04 02:44 PM |
