Robert Tenet wrote: Would you fly? probably. -- Bob Noel Looking for a sig the lawyers will hate |
Do not feed the trolls.
What troll? It's a legitimate question, especially considering that not everyone here has oodles of experience. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
"Jose" wrote in message
. .. Do not feed the trolls. What troll? It's a legitimate question, especially considering that not everyone here has oodles of experience. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. Check out Wikipedia "Internet Trolls" |
Why? I know what a troll is. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
![]() "Robert Tenet" wrote in message ... The situation: The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? Yes. |
You can't be serious.....possibly not flying because there's no radio.
Robert Tenet wrote: The situation: The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? |
![]() "Robert Tenet" wrote in message ... The situation: The aircraft was originally certified without an electrical system. It's usually flown with a handheld radio powered by a battery. The battery is dead. The airport is non-towered. The wind is nearly 90 degrees crosswind. You haven't been able to fly in 4 weeks, and if you don't fly today, you won't be able to get in the air for at least another week. Would you fly? Absolutely without a doubt. What the heck does a radio have to do with a crosswind? |
"Dave Stadt" wrote:
Would you fly? Absolutely without a doubt. What the heck does a radio have to do with a crosswind? OK, no one said "No," and in fact, that's what I did - I flew. The answer to the question of "What the heck does a radio have to do with a crosswind?" is that I was concerned about traffic switching ends. I couldn't monitor AWOS or hear traffic announcements. That didn't actually bother me at all - I'm a "see and avoid" guy who is quite happy NORDO, but I'm at a new airport and didn't want to get a reputation for recklessness and turning on final for runway 27 as some other aircraft taxis onto runway 9 for departure - which is of course exactly what happened. Another question was why I didn't just buy batteries. The handheld radio was wired into a portable intercom/radio power system that used a lead acid rechargeable. The handheld part worked, but it's impossible to hear outside of the intercom. I actually carried a spare lead acid battery. I thought they were both dead, but it later turned out to be a damaged wire inside the portable system. We've looked at my decision to fly - let's work on other decisions I made and see how they hold up under the withering r.a.p spotlight (criticism? analysis?). 1) This aircraft has not been in the air in a a month, and it's 60 years old, with a tiny (low climb rate, but relatively quiet) engine. I'm going to do one pattern just to check things out. My personal preference is to stay well within gliding range of the airport at all times on this first pattern. To completely achieve that desired safety goal, given my limited climb rate, means I would have to cheat on the noise abatement (fly rwy hdng 'til 1000' AGL) and the pattern altitude (1000'AGL). What would you do on this first flight? a) Fly well beyond glide range and comply exactly with noise abatement/pattern altitude, or b) Fudge altitudes to stay closer. 2)I departed in the direction the last aircraft used, which seemed a reasonable direction in the variable wind. As I turned final I saw an aircraft rising into the air at the opposite end of the runway. Initially I thought it was moving away from me, but then realized it was coming towards me. It's moving to my left, his right, and will be well to one side of the runway and above my altitude if I continue my descent to land. There is no other visible traffic. What would you do ... a) maneuver and reenter the pattern. If you maneuver, how would you maneuver? b) land anyway. Thanks for your comments. It's moving off runway centerline to my left and , but then |
within gliding range of the airport at all times on this first pattern. To completely achieve that desired safety goal, given my limited climb rate, means I would have to cheat on the noise abatement (fly rwy hdng 'til 1000' AGL) and the pattern altitude (1000'AGL). What would you do on this first flight? This depends on how "first" the flight is. If I had a concern for safety, that overrides all noise abatements rules. What's ahead of me and around the airport that could be used as a (safe but less convenient) landing spot should the fan stop? Flat farmland? I'd probably fly the regular pattern unless I had reason to think something was amiss. Rocky pointy things all around, and this is a first flight after maintanance? I'd cheat noise abatement... I might even ignore it totally. 2)I departed in the direction the last aircraft used, which seemed a reasonable direction in the variable wind. As I turned final I saw an aircraft rising into the air at the opposite end of the runway. Initially I thought it was moving away from me, but then realized it was coming towards me. It's moving to my left, his right, and will be well to one side of the runway and above my altitude if I continue my descent to land. I'd probably cheat to the right to let him pass to my left, continuing my approach to land, being especially vigilant for another takeoff and for other traffic that might be landing. One airplane going the wrong way does not change the pattern at an uncontrolled airport - he might have just been near his departure end and didn't want to taxi. Some pilots are like that, and if the wind is not clearly favoring either runway (you said it was 90 degree crosswind), you are NORDO and he didn't see you take off, it's not unreasonable either. (It can be argued that it is unreasonable for him to not see you in the pattern, but that's another argument and not relevant, since it is incumbant upon you to watch out for the dummies ![]() Even if you had a radio, he might not be using one. At uncontrolled airports, OSP is far more important than RSP. Jose *Optical separation procedures, Radio separation protocol. -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
MX385 Radio removal | Marty from Florida | Owning | 3 | May 24th 13 08:26 AM |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
