Canadian holding procedures
Old July 14th 04, 07:25 AM
Martin Kosina
That's it - no more, no less. On the missed, you either talk to ATC
(or you follow lost comm. procedures) or you are uncontrolled and on
your own.
That is a good point (many people who learned to fly IFR in the lower
48 and southern Canada don't think of it that way, but the airspace
system is designed to allow instrument flight from takeoff to
touchdown without ever talking to anybody). But I think the
discussion was not largely misunderstood, the basic question was what
is the clearance limit at the end of an IAP in *controlled* airspace,
and besides Frank's reference to the AIP, this has gone unanswered.
Is it the MAP, at which point you enter either a published or standard
holding pattern, or the alternate airport ?
Sorry, not to nit-pick, but this is a real scenario - I just missed an
approach, got busy reconfiguring the airplane and I am reaching the
"climb-to" altitude 0.5nm from the MAP with its *depicted* racetrack
pattern at 120 knots. The frequency is congested and I can't get a
word in. What should I do in Canada ?
Old July 14th 04, 04:23 PM
gwengler
the basic question was what is the clearance limit at the end of an IAP in
Martin,
good point. Here's my answer: The clearance limit is the Missed
Approach Holding Fix, i.e. the last point of the missed approach
procedure unless other instructions were received. AIP RAC 9.26
clearly regulates the scenario where you are not in contact with ATC
by then. Im writing from memory here, but you're supposed to hold
standard on the inbound track to the fix (whatever that may be) or in
any depicted holding patterns incl. shuttle holds or some other very
specific provisions. There you hold until you talk to someone or you
run out of options...
All the best,
Gerd
Old July 22nd 04, 04:03 PM
David Megginson
by then.
Here's the actual text, since (sadly) the AIP is not available online. Note
that in practice, controllers nearly always give specific missed approach
instructions in advance when you're landing in low IMC.
RAC 9.26 Missed Approach Procedures
Whenever a pilot conducts a published missed approach from an instrument
approach procedure, the aircraft must continue along the published final
approach course to the published Missed Approach Point (MAP) and follow the
published missed approach instructions. The pilot may climb immediately to
the altitude specified in the missed approach procedure or assigned by ATC.
In the event of a missed approach when no missed approach clearance has
been received, the pilot will follow the published missed approach
instructions. Should the pilot arrive at the missed approach holding fix
prior to receiving further clearance, the pilot will:
(a) hold in a standard holding pattern on the inbound track used to arrive
at the fix;
(b) if there is a published missed approach track to the fix, hold in a
standard holding pattern inbound to the fix on this track;
(c) if there is a published shuttle or holding pattern at the fix, hold in
this pattern regardless of the missed approach track to the fix; or
(d) if there are published missed approach holding instructions, hold in
accordance with these.
If a clearance to another destination has been received, the pilot shall, in
the absence of other instructions, carry out the missed approach
instructions until at an altitude which will ensure adequate obstacle
clearance before proceeding on course.
If specific missed approach instructions have been received and
acknowledged, the pilot is required to comply with the new missed approach
instructions before proceeding on course, e.g., "on missed approach, climb
straight ahead to 3 000 feet; right turn, climb on course" or "on missed
approach, climb straight ahead to the BRAVO NDB before proceeding on course".
Civil and military air traffic control procedures do not require the air
traffic controller to provide terrain and obstacle clearance in their missed
approach instructions. Terms such as "on missed approach, right turn climb
on course" oir "on missed approach, left turn on course" are not to be
considered specific missed approach instructions. It remains the pilot's
responsibility to ensure terrain and obstacle avoidance and clearance.
All the best,
David
Old July 14th 04, 04:43 PM
Teacherjh
the [Canadian] airspace
What besides the big sky principle separates aluminum?
Jose
Old July 14th 04, 08:01 AM
Martin Kosina
your own.
Old July 14th 04, 01:37 AM
gwengler
As another poster said correctly (that's what I kinda meant by lost
comm. procedures) refer to AIP RAC 9.26 where there is a whole list of
holding options if you don't get hold of ATC before reaching the
missed approach holding fix. But - as in the US - you cannot hold
forever and then it's off to the lost comm. procedures.
Gerd
Canadian Aviation Expo - Europa will be attending Pete Home Built 0 June 17th 04 01:10 PM
FAA's Instrument Procedures Handbook Barry Instrument Flight Rules 3 June 5th 04 07:31 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Requirement to fly departure procedures [email protected] Instrument Flight Rules 77 October 15th 03 06:39 PM
Holding Pattern Entries Dan Luke Instrument Flight Rules 17 July 11th 03 05:18 AM
