On Fri, 5 May 2006, pittss1c wrote:
Does anyone here have any experience with marine fuel flow instruments on aircraft? I have flown with the Navman unit for a few years now. I think that I paid about $150 for it. I found it on Ebay at BoatersWorld. There is a little impeller which spins as the fuel flows through it, the instructions tell you to install a fuel filter before the transducer, which I did. It works fine. If the was enough crap in the fuel to block the transducer, it would also foul the carb. No bypass needed. I like it. George Graham RX-7 Powered Graham-EZ, N4449E Homepage http://bfn.org/~ca266 |
![]() "George A. Graham" wrote in message ... On Fri, 5 May 2006, pittss1c wrote: Does anyone here have any experience with marine fuel flow instruments on aircraft? I have flown with the Navman unit for a few years now. I think that I paid about $150 for it. I found it on Ebay at BoatersWorld. There is a little impeller which spins as the fuel flows through it, the instructions tell you to install a fuel filter before the transducer, which I did. It works fine. If the was enough crap in the fuel to block the transducer, it would also foul the carb. No bypass needed. You don't necessarily need crap to block the transducer, the design of the impeller paddles in some units will block flow if the impeller seizes. |
![]() "John Kunkel" wrote in message ... "George A. Graham" wrote in message ... On Fri, 5 May 2006, pittss1c wrote: Does anyone here have any experience with marine fuel flow instruments on aircraft? I have flown with the Navman unit for a few years now. I think that I paid about $150 for it. I found it on Ebay at BoatersWorld. There is a little impeller which spins as the fuel flows through it, the instructions tell you to install a fuel filter before the transducer, which I did. It works fine. If the was enough crap in the fuel to block the transducer, it would also foul the carb. No bypass needed. You don't necessarily need crap to block the transducer, the design of the impeller paddles in some units will block flow if the impeller seizes. Agreed. And the other 'area of concern' (at least for me) was the fact the transducer has hosebarbs (cannot use AN fittings). Not good. I like the product and run one on my Glasply 19' boat. I would not run it on my aircraft. |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
Who does flight plans? | Michael 182 | Piloting | 158 | July 4th 05 02:50 AM |
Arrow II fuel flow | joe | Owning | 3 | June 23rd 05 05:54 AM |
