Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
aircraft airconditioning
Old May 31st 06, 11:09 PM posted to rec.aviation.misc
Default aircraft airconditioning
All airliners basicly use a freon sytem (seldom) or "air
cycle" packs. (common)
Air packs are simple and light, but use a LOT of fuel to operate.
Freon systems are MUCH heavier and more complex, but more efficient.
Old June 1st 06, 08:46 PM posted to rec.aviation.misc
"LincTex" wrote in message
The air packs only consume fuel when the APU is used as an air source, in
flight the engine bleed air is the air source and uses very little if any
extra fuel.
Old June 2nd 06, 02:05 AM posted to rec.aviation.misc
extra fuel.
Not true about the lack of fuel use. In the B-727, the center engine
does not typically provide bleed air for the packs in flight, and burns
200-300 less pounds-per-hour in cruise than the pod engines.
Happy Flying!
Scott Skylane
Old June 4th 06, 03:11 PM posted to rec.aviation.misc
If you have been on a long flight several hours you will notice the
aircraft get very warm inside. This is because the bleed air is shut
off from the air packs to save fuel. Some airlines pay the pilots
additional salary if they save fuel. This is why many airlines don't
start all the engines until they are at the end of the taxiway. Fuel
is money bleed air costs fuel, cool air cost money.
Stache
aircraft airconditioning [email protected] General Aviation 1 December 5th 05 04:28 AM
