dancing airplane
Old June 8th 06, 10:15 PM posted to rec.aviation.piloting
Default dancing airplane
I'm as awed now as I was when I first saw it months ago.
How much would such an airplane, together with it's R/C cost
approximately?
Ramapriya
well.....a ready to fly gas kit can be found for under $300, and you can
even find some non-aerobatic electric kits for under $100.
of course to get as skilled as the dancing plane you are gonna crash about
$1500 worth of those kits
the flying lawnmower will be a bit cheaper, as the lawnmower is not an
aerobatic kit, and "should" be less crash prone.
Old June 9th 06, 07:43 AM posted to rec.aviation.piloting
And will these thingeys get destroyed on a crash too or are they kindly
towards learners? I ask because where I am, I might just find one of
these in a store somewhere but will certainly not find an instructor
and I'll have to teach myself
Ramapriya
Old June 9th 06, 03:40 PM posted to rec.aviation.piloting
about
Ramapriya
In which case you want to look for what the models guys refer to as a
foamie. The fuselage, wings, and stabilizers are molded from rigid
polystyrene(sp?). Almost indestructible.
Old June 9th 06, 06:23 PM posted to rec.aviation.piloting
about
the sub- $300 ones (sometimes sub $100) are the foamies casey talks about in
the other reply. usualy on a bad crash the bust a prop (a $3-5 item) or
maybe crack a wing (fixed with packing tape)
talk to the saledroids and see if there is a club nearby. an hour of
instruction can save hundreds of hours of self teaching.
also a club can make sure you do not learn bad habits.
also go check rec.models.rc.air and see. smaller planes, same politics.
one added issue to RC is that you need to mentaly reverse half the controls
when the plane is coming towards you. that and being hamfisted at the
controls are the two biggest issues about flying rc planes
Crash In The Nolichucky W P Dixon Piloting 2 June 22nd 05 05:16 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
The Best Airplane Veeduber Home Built 1 February 13th 04 06:43 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 3rd 04 12:41 AM
