The display window for the KY197 Com consists of two pieces of
plastic. The front piece is clear with just three labels on it. "use, standby, and comm". The back piece is of a light amber color and matches the front piece for shape and has a black mask to hide everything behind the window except the readout. Some where in the history of the radio, it has either: 1. Been cleaned with a solvent 2. Had someone try to glue the two pieces together 3. The two pieces were glued together and heat caused them to separate At any rate the radio works fine and looks good except for the internal distortion in the window. I'd like to replace that window. Being old, purchasing a new panel/faceplate would cost more than the radio is worth. Any one know where I can find the amber colored plastic. I can probably make the one out of clear and add the lettering. OTOH I probably could, using Plexiglas glue fit the two together so the distortion doesn't show. However I'm unwilling to try something that drastic without having a "back up" in case it doesn't work. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger" wrote in message ... The display window for the KY197 Com consists of two pieces of plastic. The front piece is clear with just three labels on it. "use, standby, and comm". The back piece is of a light amber color and matches the front piece for shape and has a black mask to hide everything behind the window except the readout. Some where in the history of the radio, it has either: 1. Been cleaned with a solvent 2. Had someone try to glue the two pieces together 3. The two pieces were glued together and heat caused them to separate At any rate the radio works fine and looks good except for the internal distortion in the window. I'd like to replace that window. Being old, purchasing a new panel/faceplate would cost more than the radio is worth. Any one know where I can find the amber colored plastic. I can probably make the one out of clear and add the lettering. OTOH I probably could, using Plexiglas glue fit the two together so the distortion doesn't show. However I'm unwilling to try something that drastic without having a "back up" in case it doesn't work. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com One of two places, get in the yellow pages and look under 'plastics distributors', most shops sell leftover scraps for cheap. Also, you may have some luck with a good hobby shop for various kinds of clear plastic sheet. Mke |
![]() "Roger" wrote in message ... Any one know where I can find the amber colored plastic. I can probably make the one out of clear and add the lettering. OTOH I probably could, using Plexiglas glue fit the two together so the distortion doesn't show. However I'm unwilling to try something that drastic without having a "back up" in case it doesn't work. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com TAP Plastics http://www.tapplastics.com/aa/pinfo/...te_pantone.pdf http://www.tapplastics.com/info/acrylic.php? Acrylite GP It comes in most colors of the rainbow. Regards, John Severyn @KLVK |
On Sat, 10 Jun 2006 20:58:29 -0700, "J. Severyn"
wrote: "Roger" wrote in message .. . Any one know where I can find the amber colored plastic. I can probably make the one out of clear and add the lettering. OTOH I probably could, using Plexiglas glue fit the two together so the distortion doesn't show. However I'm unwilling to try something that drastic without having a "back up" in case it doesn't work. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com TAP Plastics http://www.tapplastics.com/aa/pinfo/...te_pantone.pdf http://www.tapplastics.com/info/acrylic.php? Acrylite GP Thanks, They have it in sheets 2' X 4' at roughly $40 USD plus over size shipping. It still beats a couple hundred for the panel/face plate. I'm going to try and come up with some about a foot square. That'd be enough to do about a dozen radios. :-)) Thanks again, Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com It comes in most colors of the rainbow. Regards, John Severyn @KLVK |
![]() "Roger" wrote in message ... On Sat, 10 Jun 2006 20:58:29 -0700, "J. Severyn" wrote: "Roger" wrote in message . .. Any one know where I can find the amber colored plastic. I can probably make the one out of clear and add the lettering. OTOH I probably could, using Plexiglas glue fit the two together so the distortion doesn't show. However I'm unwilling to try something that drastic without having a "back up" in case it doesn't work. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com TAP Plastics http://www.tapplastics.com/aa/pinfo/...te_pantone.pdf http://www.tapplastics.com/info/acrylic.php? Acrylite GP Thanks, They have it in sheets 2' X 4' at roughly $40 USD plus over size shipping. It still beats a couple hundred for the panel/face plate. I'm going to try and come up with some about a foot square. That'd be enough to do about a dozen radios. :-)) Thanks again, Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com It comes in most colors of the rainbow. Regards, John Severyn @KLVK TAP normally has much smaller pieces from other jobs for sale (from custom work done on site). It might take a phone call to snag a smaller piece, but usually you can buy anything from a few square inches to a truckload. John Severyn @klvk |
On Sun, 11 Jun 2006 01:57:35 -0700, "J. Severyn"
wrote: "Roger" wrote in message .. . On Sat, 10 Jun 2006 20:58:29 -0700, "J. Severyn" wrote: "Roger" wrote in message ... Any one know where I can find the amber colored plastic. I can probably make the one out of clear and add the lettering. OTOH I probably could, using Plexiglas glue fit the two together so the distortion doesn't show. However I'm unwilling to try something that drastic without having a "back up" in case it doesn't work. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com TAP Plastics http://www.tapplastics.com/aa/pinfo/...te_pantone.pdf http://www.tapplastics.com/info/acrylic.php? Acrylite GP Thanks, They have it in sheets 2' X 4' at roughly $40 USD plus over size shipping. It still beats a couple hundred for the panel/face plate. I'm going to try and come up with some about a foot square. That'd be enough to do about a dozen radios. :-)) Thanks again, Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com It comes in most colors of the rainbow. Regards, John Severyn @KLVK TAP normally has much smaller pieces from other jobs for sale (from custom work done on site). It might take a phone call to snag a smaller piece, but usually you can buy anything from a few square inches to a truckload. I already received a not back from them that they don't stock the transparent amber in 1/16" thickness. I may have to put the thin piece between to pieces of clear. I'll give them a call during business hours tomorrow. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com John Severyn @klvk |
