Unusual Vacuum system indication, please help explain.
Old June 13th 06, 12:33 AM posted to rec.aviation.ifr,rec.aviation.piloting
Default Unusual Vacuum system indication, please help explain.
So, even if it had a pressure pump, wouldn't the original question be the
same? i.e. How does a failure(open) in the system produce a high
Vacuum/Pressure?
This is kind of embarassing for someone like me who "knows everything".
Shields are up, captain.
Al G
"swag" wrote in message
I know the guage in the P337 looks like the guage on the Bonanza I used
to fly--and that had a pressure pump. The pins would pop out if the
pump didn't deliver enough pressure.
I fly a P337 and should know if it has vacuum pumps or pressure pumps,
but I don't (red face)
Al wrote:
Hmmm, the little red pins on the gauge that stuck out when stopped, and
retracted when we started, said "Vacuum Source". We didn't have vacuum
pumps
on the Lear, but did on the C-340.
Al G.
"karl gruber" wrote in message
All the pressurized airplanes I've flown have "pressure" not vacuum
systems.
Karl
ATP, CFI, ETC
"Curator" N185KG
"Al" wrote in message
news Hi Group.
I had a trip Friday in a 1977 C-337G(pressurized). On the taxi out
I
noticed the suction gauge was pegged high. The AI erected ok, but the
DG
required many updates on the way to the run-up area. Pulling on to the
runway, we corrected the DG again, by 30 degrees.
We flew VFR to Boise, and checked out the new Garmin 530 just
installed. Once we got on the ground, the avionics guy, we had along,
pulled the access panel in front of the left windshield. On the back
of
the panel there is a component that looks like the back of an
altimeter,
only about half as deep. It has a tube labeled "Air IN" and this one
had
no hose attached. Nearby was a loose hose, which we reconnected. The
system worked fine, and we had no more problems.
Can anyone explain to me how opening a fault anywhere in vacuum
system
can deliver a high vacuum? The gauge worked normally, low before
start,
rising when the engine lit off. Two source indicators both showed a
working pump on each engine. I assume the component I was looking at
was
a regulator, but I fail to see how the fault we found, could give us
indication we saw.
Al G (There is another Al on the goup now )
