Corrosion at Aluminum/Steel Junction
Old June 20th 06, 03:05 PM posted to sci.military.naval,rec.aviation.homebuilt
Default Corrosion at Aluminum/Steel Junction
On Mon, 19 Jun 2006 18:34:46 +0000, Front Office
I need to build a dozen outdoor canopies for an office building.
I want to use structural aluminum channel, bolted with steel bolts.
Where might expect corrosion to arise over the years, and would
it be mainly in the aluminum or in the steel bolts?
Thanks for any help.
Please post here or email me at grayscale[AT]verizon.net
Ralph
a product called Duralac is designed to prevent the electrolytic
corrosion between dissimilar metals.
it is an aviation product made in england. comes in a white and yellow
tube.
it is a toothpaste consistency yellow fluid containing zinc chromate.
it dries slowly to a rubber consistency.
the stuff is used for pop rivets with great benefit in corrosion
control. you just dip them in it prior to setting the pop in a wing
skin.
it is good stuff. two tubes in my aviation tool box.
Stealth Pilot
Old June 21st 06, 12:41 AM posted to sci.military.naval,rec.aviation.homebuilt
On Tue, 20 Jun 2006 22:05:55 +0800, Stealth Pilot
tube.
Minor point, it only contains Barium Chromate and White Spirit.
You can also buy bigger tins of it, It's used in a lot of marine
applications as well as aviation.
Old June 21st 06, 02:32 PM posted to sci.military.naval,rec.aviation.homebuilt
On Wed, 21 Jun 2006 00:41:07 +0100, Martin Evans
tube.
had to drag out my tube.
that's true.
Stealth Pilot
Old June 22nd 06, 03:21 PM posted to sci.military.naval,rec.aviation.homebuilt
tube.
that's true.
Stealth Pilot
Hard to get zinc chromate in the average consumer product
anymore. It's been linked to cancer. Zinc *oxide* is often seen in
those green aerosol primers now. I can still get Endura epoxy zinc
chromate, clearly labelled "for industrial use only."
Dan
Old June 25th 06, 11:16 PM posted to sci.military.naval,rec.aviation.homebuilt
In message .com,
writes
Milspec products a decade ago used to use strontium chromate in a grease
base, but even then the search was on for a less unfriendly replacement.
Paul J. Adam
Pilatus B4 and corrosion Mika Koski Soaring 1 April 26th 06 09:50 PM
Corrosion Evaluation Help Dick Home Built 3 July 15th 05 02:51 AM
Surface Corrosion? Joaquin Murrieta Home Built 2 May 3rd 05 01:19 AM
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
