Feel free to look me up on the FAA web. Certificated
airplanes are designed to not fully stall the wing or the tail for that matter. But within the limits of what does happen, and without discussing wash-in, wash-out, twist, airfoil section changes, control stops, stick shaker and pullers, gust loading, accelerated stalls, mushing, getting a useable idea of what happens when the controls are applied smoothly, violently or the airplane breaks apart in flight. If the nose would always go down from a stall, spin chutes would not be required. If the airplane is abused in flight, it will do some pretty remarkable things. I know a Beech test pilot who wondered about what would happen in an E90 at cruise if you put the props into reverse. The airplane did not break, but they were reported to have changed their clothes after the flight. Same pilot tried the same thing in an F90 with the T-tail and nothing really uncontrollable happened. It is possible to design a wing that will stall, 100% across the entire span, but it won't be certified for civil use. If the tail surface reaches max lift (down-force) and you try to go slower, it will begin the stall as air flow reaches the critical angle of attack on the tail PROGRESSIVELY and the nose will drop because the moment between the CP and CG will not be countered by the tail forces. Do it slowly and the nose pitches down slowly. Pull a few Gs and the reaction is faster and the degree to which the stall progresses on the tail and wing is much faster because inertia will carry the aircraft past the critical angles at a higher kinetic energy level. -- James H. Macklin ATP,CFI,A&P "Matt Whiting" wrote in message ... | Jim Macklin wrote: | | Unless the wing is producing lift, there is no rotation to | reduce the angle of attack. If the wing was really stalled, | the airplane would fall flat, if it was spinning it would be | a flat spin, but if was fully stalled, it would be a deep | stall and would not rotate the nose down and it would stay | in the stall. | | The lift from the wing doesn't go to zero during a stall. | | | Under normal conditions, neither the wing or the tail fully | stalls. Stall strips, wing twist or air foil changes along | the span keep the wing from reaching the critical angle of | attack at one moment in time. Also the tailplane is usually | a different airfoil and more heavily loaded and is designed | to begin shedding lift [down-force] before the wing. The CG | range is set so that a certified airplane will have that | stable pattern. | | I'm now really curious to hear your definition of what stall means. | | | The weight of the airplane does not cause the stall break | rotation, it is the lift moment. If it was not for the wing | lift, the airplane's mass as concentrated on the CG would | simply fall as a unit in the same attitude as it was in at | the moment. | | No it won't because there is still some lift from the wing, however, it | is now less than the weight of the airplane so the imbalance in forces | causes the airplane to both descend and rotate. It would only fall | downward in a flat attitude of the lift (and drag) of the wing and tail | and fuselage went either completely to zero or remained perfectly equal | forward and rearward of the CG. | | | | If the center of pressure was located at the same location | as the CG, there would be no moment or force to cause | rotation. | | Sure, there is still the force from the tail. | | Are you really a CFI and ATP as your .sig advertises? | | Matt |
Jim Macklin wrote:
Feel free to look me up on the FAA web. Certificated airplanes are designed to not fully stall the wing or the tail for that matter. But within the limits of what does happen, and without discussing wash-in, wash-out, twist, airfoil section changes, control stops, stick shaker and pullers, gust loading, accelerated stalls, mushing, getting a useable idea of what happens when the controls are applied smoothly, violently or the airplane breaks apart in flight. If the nose would always go down from a stall, spin chutes would not be required. If the airplane is abused in flight, it will do some pretty remarkable things. I know a Beech test pilot who wondered about what would happen in an E90 at cruise if you put the props into reverse. The airplane did not break, but they were reported to have changed their clothes after the flight. Same pilot tried the same thing in an F90 with the T-tail and nothing really uncontrollable happened. It is possible to design a wing that will stall, 100% across the entire span, but it won't be certified for civil use. If the tail surface reaches max lift (down-force) and you try to go slower, it will begin the stall as air flow reaches the critical angle of attack on the tail PROGRESSIVELY and the nose will drop because the moment between the CP and CG will not be countered by the tail forces. Do it slowly and the nose pitches down slowly. Pull a few Gs and the reaction is faster and the degree to which the stall progresses on the tail and wing is much faster because inertia will carry the aircraft past the critical angles at a higher kinetic energy level. I've never seen this discussed in any book on aerodynamics that I've ever read. Do you have even one credible reference to support your claims? Matt |
No, do I need a credible reference?
-- James H. Macklin ATP,CFI,A&P "Matt Whiting" wrote in message ... | Jim Macklin wrote: | Feel free to look me up on the FAA web. Certificated | airplanes are designed to not fully stall the wing or the | tail for that matter. But within the limits of what does | happen, and without discussing wash-in, wash-out, twist, | airfoil section changes, control stops, stick shaker and | pullers, gust loading, accelerated stalls, mushing, getting | a useable idea of what happens when the controls are applied | smoothly, violently or the airplane breaks apart in flight. | | If the nose would always go down from a stall, spin chutes | would not be required. If the airplane is abused in flight, | it will do some pretty remarkable things. I know a Beech | test pilot who wondered about what would happen in an E90 at | cruise if you put the props into reverse. The airplane did | not break, but they were reported to have changed their | clothes after the flight. Same pilot tried the same thing | in an F90 with the T-tail and nothing really uncontrollable | happened. | | It is possible to design a wing that will stall, 100% across | the entire span, but it won't be certified for civil use. | | If the tail surface reaches max lift (down-force) and you | try to go slower, it will begin the stall as air flow | reaches the critical angle of attack on the tail | PROGRESSIVELY and the nose will drop because the moment | between the CP and CG will not be countered by the tail | forces. Do it slowly and the nose pitches down slowly. | Pull a few Gs and the reaction is faster and the degree to | which the stall progresses on the tail and wing is much | faster because inertia will carry the aircraft past the | critical angles at a higher kinetic energy level. | | I've never seen this discussed in any book on aerodynamics that I've | ever read. Do you have even one credible reference to support your claims? | | Matt |
Jim Macklin wrote:
No, do I need a credible reference? Only if you want us to believe you as what you are saying goes against everything most of us have seen published in the literature. Matt |
I don't care what you believe. Maybe I just wanted a heated
discussion to start, or maybe there is another reason. Factors to consider... CG range approved Actual operational CG condition of the airfoils pilot technique Let see what this logic shows... aircraft is slowed to near stalling speed by the application of back pressure on the elevator which increases the down force on the aircraft tail cone which levers the nose upward by dynamically shifting the CG to a point behind the CP which is the moment arm of the tail times the force produced by the tail in an algebraic balance with the arm of the CG and CP. If the tail does not stall, to some degree, what tail down force ceases to exist to maintain the nose up attitude? If the wing is stalled does the lift not decrease and thus the CP force decrease? Would that not reduce the moment needed to rotate the nose downward to regain flying speed reduce the angle of attack)? FAR 23 has design limits for control degradation, the rudder must be able to yaw the aircraft at a speed less than lift-off speed, the elevator must be able to apply forces and even the ailerons have limits. But when the aircraft is stalled, out of ground effect, what force or forces change that cause the nose to pitch downward? The wing is producing less lift which means that the moment produced by wing lift also decreases, reducing the nose down force. The tail was supplying the force needed to establish the attitude and what would cause THAT forced to be reduced if it is not at least a stall (partial or complete) of the elevator? If the aircraft is held in a stalled condition, with the elevator full back and the aircraft has a stall break, the nose drops and then the nose pitches back up and the stall break happens again and again in a cycle, the pilot keeping the elevator full back and the wings level with rudder and some aileron if the ailerons still function, what change in forces on the aircraft is causing the cycle? Did the wing regain lift or did the tail regain down-force? -- James H. Macklin ATP,CFI,A&P "Matt Whiting" wrote in message ... | Jim Macklin wrote: | No, do I need a credible reference? | | Only if you want us to believe you as what you are saying goes against | everything most of us have seen published in the literature. | | Matt |
Jim Macklin wrote:
I don't care what you believe. Confirms my suspicion. You don't care about being correct either so no need for further discussion. Ignorance is bliss. Matt |
"Jim Macklin" wrote in message
news:Z6vmg.49402$ZW3.30156@dukeread04... "Matt Whiting" wrote: Jim Macklin wrote: No, do I need a credible reference? Only if you want us to believe you as what you are saying goes against everything most of us have seen published in the literature. I don't care what you believe. You're a CFI, so we care what your students are led to believe. Maybe I just wanted a heated discussion to start, Uh, sure Jim. But there's been little heated discussion. Several of us have just been patiently explaining to you an elementary aspect of aviation. If the tail does not stall, to some degree, what tail down force ceases to exist to maintain the nose up attitude? That's a perfectly reasonable question, and it's been answered for you at least five times in this thread. (Hint: search for "relative wind".) Each time, you've simply *ignored* the answer without even *trying* to point out any flaw in it. Your approach to discussing aviation is the same as your approach to discussing politics. In both domains, you're willing to engage in debate *as long as it just rehashes material that's already familiar to you*. But as soon as anyone raises an objection that you hadn't previously considered, you just ignore it and retreat to familiar ground, repeating the claims that the objection already defeated, making no attempt to refute the objection. Unfortunately, that approach completely defeats the purpose of rational discourse, because it renders your beliefs incorrigible. Perversely, you're left with the illusion that you've sustained your position; but the reality is that you merely went through the motions of rational discourse until just before the point where a meaningful exchange of ideas would begin. --Gary |
Gary Drescher wrote:
That's a perfectly reasonable question, and it's been answered for you at least five times in this thread. (Hint: search for "relative wind".) Each time, you've simply *ignored* the answer without even *trying* to point out any flaw in it. It is pretty clear that he doesn't want to know the correct answer. Yes, it is sad that he's a CFI and propogating these OWTs to his students. It is even scarier than the system let him get to the ATP level with this erroneous thinking. Maybe I'll try to get a note to Barnaby Wainfan and see if he'll address it in one of his future columns. I know he's dicussed stalls before, but I'm not sure from this perspective of level of detail. Matt |
Sorry, I've been attempting to emulate the mental processes
of a Democrat. "Gary Drescher" wrote in message . .. | "Jim Macklin" wrote in message | news:Z6vmg.49402$ZW3.30156@dukeread04... | "Matt Whiting" wrote: | Jim Macklin wrote: | No, do I need a credible reference? | | Only if you want us to believe you as what you are saying goes against | everything most of us have seen published in the literature. | | I don't care what you believe. | | You're a CFI, so we care what your students are led to believe. | | Maybe I just wanted a heated discussion to start, | | Uh, sure Jim. But there's been little heated discussion. Several of us have | just been patiently explaining to you an elementary aspect of aviation. | | If the tail does not stall, to some degree, what tail down | force ceases to exist to maintain the nose up attitude? | | That's a perfectly reasonable question, and it's been answered for you at | least five times in this thread. (Hint: search for "relative wind".) Each | time, you've simply *ignored* the answer without even *trying* to point out | any flaw in it. | | Your approach to discussing aviation is the same as your approach to | discussing politics. In both domains, you're willing to engage in debate *as | long as it just rehashes material that's already familiar to you*. But as | soon as anyone raises an objection that you hadn't previously considered, | you just ignore it and retreat to familiar ground, repeating the claims that | the objection already defeated, making no attempt to refute the objection. | | Unfortunately, that approach completely defeats the purpose of rational | discourse, because it renders your beliefs incorrigible. Perversely, you're | left with the illusion that you've sustained your position; but the reality | is that you merely went through the motions of rational discourse until just | before the point where a meaningful exchange of ideas would begin. | | --Gary | | |
"Jim Macklin" wrote:
I don't care what you believe. Maybe I just wanted a heated discussion to start This is called being a troll, and is generally not something which most people appreciate. aircraft is slowed to near stalling speed by the application of back pressure on the elevator which increases the down force on the aircraft tail cone which levers the nose upward by dynamically shifting the CG to a point behind the CP which is the moment arm of the tail times the force produced by the tail in an algebraic balance with the arm of the CG and CP. This is gibberish. The CG doesn't shift unless stuff moves around in the airplane. A study of shifting loads (such as fuel sloshing around in half-full tanks) would be a fascinating but very complicated endeavor, and not particularly germane to this discussion. If the tail does not stall, to some degree, what tail down force ceases to exist to maintain the nose up attitude? OK, I explained this once, but I'll do it again, slowly, and more carefully. Let's invent a hypothetical airplane where the main wing stalls at an alpha (angle of attack, AOA) of 18 degrees, which happens to be a fairly typical number for the kinds of wings most of us fly. Let's also imagine that it's got a symmetric one-piece stabilator (such as found on an Archer), which also stalls at 18 degrees (positive or negative). Vso for this plane is 60 kts (that's a pretty high value, but it makes the math easier Now, let's put the plane at the edge of stall in a typical power-off stall demonstration. The main wing AOA is 17.9 degrees. The yoke is almost all the way back, and the stabilator is set at an AOA of -15 degrees. Power is at idle, true airspeed is 50 kts, and you're maintaining altitude. Now, pull back on the yoke just a bit more. The AOA increases to 18.1 degrees, and the main wing is now stalled. The wing is now producing less lift than the airplane weighs, so it starts to accelerate downward. After a short time, it's in a 100 fpm descent, but we're still holding the same pitch attitude. If you work the math, 60 KTAS and 100 fpm down works out to a glide slope of just about -1 degree, which means the relative wind is now coming from 1 degree below the horizontal. Since the pitch angle hasn't changed, the AOA of both the main wing and the tail will change by this same 1 degree. For the main wing, that means the AOA has been driven from 18.1 degrees to 19.1 degrees; further into stall, and further reducing the amount of lift being generated (increasing drag too, but that's a secondary issue). Now, here's the interesting part. The tail has gone from -15 to -14. It's moved further away from stall. But, it too, is producing less (downward) lift because the AOA is reduced. Less downforce from the tail means the nose will start to drop. No tail stall, just reduced downwards lift from the tail due to decreased tail AOA caused by the downward motion of the aircraft. That's it, I'm done. If you really want to be a troll, enjoy yourself. If the wing is stalled does the lift not decrease and thus the CP force decrease? Would that not reduce the moment needed to rotate the nose downward to regain flying speed reduce the angle of attack)? FAR 23 has design limits for control degradation, the rudder must be able to yaw the aircraft at a speed less than lift-off speed, the elevator must be able to apply forces and even the ailerons have limits. But when the aircraft is stalled, out of ground effect, what force or forces change that cause the nose to pitch downward? The wing is producing less lift which means that the moment produced by wing lift also decreases, reducing the nose down force. The tail was supplying the force needed to establish the attitude and what would cause THAT forced to be reduced if it is not at least a stall (partial or complete) of the elevator? If the aircraft is held in a stalled condition, with the elevator full back and the aircraft has a stall break, the nose drops and then the nose pitches back up and the stall break happens again and again in a cycle, the pilot keeping the elevator full back and the wings level with rudder and some aileron if the ailerons still function, what change in forces on the aircraft is causing the cycle? Did the wing regain lift or did the tail regain down-force? |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| Practice stalls on your own? | [email protected] | Piloting | 34 | May 30th 05 06:23 PM |
| Newbie Qs on stalls and spins | Ramapriya | Piloting | 72 | November 23rd 04 05:05 AM |
| military men "dumb, stupid animals to be used" Kissinger | B2431 | Military Aviation | 3 | April 26th 04 06:46 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
