Dale wrote:
Anyone know what they are? Any idea where to look to find the info? I've looked at the TDC and didn't see it listed. TIA Dale, Talked to a guy who has an old Army Flight Manual, and one of Warren Woods', too. He described a graph in the Army book that showed a limit of 3.0 G's at 26000 lbs, sloping to 2.5 G's at 30600 lbs, and then extending into the "caution" zone up to about 36000 lbs. The Woods manual listed several configurations, from flaps 0 to flaps 45, and various angles of attack. Basically, these values ranged from +/- 2.83 G's, down to +0.44 G's, all at 26900 lbs. These values seem consistant with CAR 4b, which it was probably certified under. 4b states a minimum of 2.5 Gs. I suspect these figures are in reality *very* conservative, as no one I've ever talked to has heard of a -3 falling out of the sky due to load induced structural failure. Happy Flying! Scott Skylane |
Scott Skylane wrote: Talked to a guy who has an old Army Flight Manual, and one of Warren Woods', too. He described a graph in the Army book that showed a limit of 3.0 G's at 26000 lbs, sloping to 2.5 G's at 30600 lbs, and then extending into the "caution" zone up to about 36000 lbs. The Woods manual listed several configurations, from flaps 0 to flaps 45, and various angles of attack. Basically, these values ranged from +/- 2.83 G's, down to +0.44 G's, all at 26900 lbs. These values seem consistant with CAR 4b, which it was probably certified under. 4b states a minimum of 2.5 Gs. I suspect these figures are in reality *very* conservative, as no one I've ever talked to has heard of a -3 falling out of the sky due to load induced structural failure. Thanks Scott! Yeah, sounds conservative to me..especially after seeing the way they're built. That gives me a start though. Thanks again. |
I've ever talked to has heard of a -3 falling out of the sky due to load induced structural failure. During the Berlin Airlift, a C-47 took off with a full load of X sheets of Perforated Aluminum Planking, for extending the destination runway. Turned out it was X sheets, but Perforated STEEL Planking.... and it still flew.. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
David Lesher wrote:
During the Berlin Airlift, a C-47 took off with a full load of X sheets of Perforated Aluminum Planking, for extending the destination runway. Turned out it was X sheets, but Perforated STEEL Planking.... and it still flew.. I don't think you can get a C-47 overgross. I do know you can get it out of cg. I've seen one spin. It's a fascinating sight. Michael |
"Michael" wrote:
David Lesher wrote: During the Berlin Airlift, a C-47 took off with a full load of X sheets of Perforated Aluminum Planking, for extending the destination runway. Turned out it was X sheets, but Perforated STEEL Planking.... and it still flew.. I don't think you can get a C-47 overgross. I do know you can get it out of cg. I've seen one spin. It's a fascinating sight. Michael From the 'outside' maybe...I'd use another word to describe the view from the 'inside...' ![]() -- -Gord. (use gordon in email) |
| Thread Tools | |
| Display Modes | |
| F/A-18 external stores load | [email protected] | Naval Aviation | 3 | December 27th 04 08:59 AM |
| If I make it stronger | Jdandy | Home Built | 9 | August 30th 04 09:22 PM |
| Stupid question about flight testing and "the envelope" | Scott Ferrin | Military Aviation | 12 | January 7th 04 04:56 AM |
| Va: maneuvering speed ad nauseam | Koopas Ly | Piloting | 14 | November 29th 03 06:07 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
