joe wrote:
Then you need to tear it down.???? If its a lycoming you need to tear it down regardless..... AD NOTE joe It's only a service bulletin, not an AD. Both Continental and Lycoming consider a teardown mandatory after a prop strike. |
no there is an AD note 2004 -10-14 i think that requires it
A few years back lycoming redefined what is a prop strike..... A manufactururer SB does not make anything mandatory for a part 91 operator. An AD note does....... Ron Natalie wrote: joe wrote: Then you need to tear it down.???? If its a lycoming you need to tear it down regardless..... AD NOTE joe It's only a service bulletin, not an AD. Both Continental and Lycoming consider a teardown mandatory after a prop strike. |
joe wrote:
no there is an AD note 2004 -10-14 i think that requires it A few years back lycoming redefined what is a prop strike..... A manufactururer SB does not make anything mandatory for a part 91 operator. An AD note does....... Ron Natalie wrote: joe wrote: Then you need to tear it down.???? If its a lycoming you need to tear it down regardless..... AD NOTE joe It's only a service bulletin, not an AD. Both Continental and Lycoming consider a teardown mandatory after a prop strike. Read the Lycoming AD/SB carefully. Just because you hit something does not mean you have to do a tear down. Michelle A&P (having read the thing more than once in the last year) |
Michelle: I agree with your assessment. Nose gear failure with "power
off" with consequence of minor prop bend may not require a tear down. Contact surface (scrape)on the prop will help determine what stresses were on the crank per my mechanic. Larry Michelle P wrote: joe wrote: no there is an AD note 2004 -10-14 i think that requires it A few years back lycoming redefined what is a prop strike..... A manufactururer SB does not make anything mandatory for a part 91 operator. An AD note does....... Ron Natalie wrote: joe wrote: Then you need to tear it down.???? If its a lycoming you need to tear it down regardless..... AD NOTE joe It's only a service bulletin, not an AD. Both Continental and Lycoming consider a teardown mandatory after a prop strike. Read the Lycoming AD/SB carefully. Just because you hit something does not mean you have to do a tear down. Michelle A&P (having read the thing more than once in the last year) |
On 8 Aug 2006 18:04:34 -0700, "joe" wrote:
no there is an AD note 2004 -10-14 i think that requires it A few years back lycoming redefined what is a prop strike..... A manufactururer SB does not make anything mandatory for a part 91 operator. An AD note does....... Even if it were only and SB which is not "officially" mandatory, let's say you have a prop strike. Every thing looks good, you replace or straighten the prop and the thing runs well. Even the run out looks good. About 50 or 100 hours later the crank lets go and you shred the thing in an off field landing although no one gets hurt. What does your insurance company say if they find out you have not complied with that particular SB? Will they pay and say nothing? Will they pay and complain? Will they raise your rates? Will they let your renew at renewal time? Who knows? Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Ron Natalie wrote: joe wrote: Then you need to tear it down.???? If its a lycoming you need to tear it down regardless..... AD NOTE joe It's only a service bulletin, not an AD. Both Continental and Lycoming consider a teardown mandatory after a prop strike. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() "Roger" wrote in message ... On 8 Aug 2006 18:04:34 -0700, "joe" wrote: no there is an AD note 2004 -10-14 i think that requires it A few years back lycoming redefined what is a prop strike..... A manufactururer SB does not make anything mandatory for a part 91 operator. An AD note does....... Even if it were only and SB which is not "officially" mandatory, let's say you have a prop strike. Every thing looks good, you replace or straighten the prop and the thing runs well. Even the run out looks good. About 50 or 100 hours later the crank lets go and you shred the thing in an off field landing although no one gets hurt. What does your insurance company say if they find out you have not complied with that particular SB? Will they pay and say nothing? Will they pay and complain? Will they raise your rates? Will they let your renew at renewal time? Who knows? They will pay. Happened to a Cherokee around here and no questions were asked. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Ron Natalie wrote: joe wrote: Then you need to tear it down.???? If its a lycoming you need to tear it down regardless..... AD NOTE joe It's only a service bulletin, not an AD. Both Continental and Lycoming consider a teardown mandatory after a prop strike. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Buying prop strike engine | [email protected] | Owning | 18 | August 14th 06 12:47 AM |
Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 12:51 AM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
Prop Feathers and Engine Shuts down after landing???????? | AIR ADVENTURE82 | Piloting | 3 | August 21st 03 05:42 AM |
