Buying prop strike engine
Old August 9th 06, 05:22 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Michelle P
Default Buying prop strike engine
joe wrote:
no there is an AD note 2004 -10-14 i think that requires it
A few years back lycoming redefined what is a prop strike.....
A manufactururer SB does not make anything mandatory for a part 91
operator. An AD note does.......
Ron Natalie wrote:
joe wrote:
Then you need to tear it down.????
If its a lycoming you need to tear it down regardless..... AD NOTE
joe
It's only a service bulletin, not an AD.
Both Continental and Lycoming consider a teardown
mandatory after a prop strike.
Read the Lycoming AD/SB carefully. Just because you hit something does
not mean you have to do a tear down.
Michelle A&P (having read the thing more than once in the last year)
Old August 12th 06, 05:42 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Larry
Michelle: I agree with your assessment. Nose gear failure with "power
off" with consequence of minor prop bend may not require a tear down.
Contact surface (scrape)on the prop will help determine what stresses
were on the crank per my mechanic.
Larry
joe
Buying prop strike engine [email protected] Owning 18 August 14th 06 01:47 AM
Engine Balancing and Resonance Vibration Problem AllanFuller Owning 13 September 12th 05 01:51 AM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 12:35 PM
Towing Roger Fowler Soaring 6 August 11th 05 05:25 AM
Prop Feathers and Engine Shuts down after landing???????? AIR ADVENTURE82 Piloting 3 August 21st 03 06:42 AM
