foam problem
Old August 11th 06, 06:57 AM posted to rec.aviation.homebuilt
Tim Ward[_1_]
Default foam problem
"Dave Lyon" wrote in message
news:avNCg.84182$FQ1.83676@attbi_s71...
Another ply on the outside will help, but eventually it will get too
heavy.
I'd go the other way. Skin the outside with 1/" wetsuit neoprene.
Really? Don't tease me, I'm an easy target. It's like making fun of
Jerry's
kids (Lewis, not Springer) , it just really should be done.
Anybody know where I can get some camo neoprene for cheap?
A slightly different solution, that may add more weight , but might be
cheaper than the denser foam:
Skin the outside with lauan doorskins. They're pretty cheap, and it should
spread the load so that the paintballs don't ding the foam.
You might consider making another test panel of fiberglass inside, foam
core, and just the doorskin outside, or a lighter-weight fiberglass cloth on
the outside.
From a cost point of view, I suspect that door skin/foam/doorskin sandwich
glued with urethane glue will be cheaper than fiberglass. I don't know what
thickness plywood you were using before, but this should have the stiffness
of 3/4 inch plywood with about a third the weight. A thicker core will
increase the stiffness without affecting the weight very much.
Tim Ward
Old August 11th 06, 02:15 PM posted to rec.aviation.homebuilt
Evan Carew
heavy.
Jerry's
the outside.
Tim Ward
The luan will eventually dent and break just like a single ply of
fiberglass on weak foam. I know, I play with paintball guns too
Evan
Heater problem fixed! Jim Burns Owning 14 December 17th 04 10:38 PM
blue foam & cutting it Richard Riley Home Built 6 November 24th 03 01:53 PM
Problem: Ground Speed Estimate with Volkslogger and WinPilot RamyYanetz Soaring 3 August 26th 03 03:06 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
