![]() "Newps" wrote in message . .. Any chance there's a point to this drivel? Herr Ludwig didn't make it clear that he is ranting AGAINST the choice of the Lycoming for all RVs. Akshully, Herr Ludwig makes no cogent remarks as he stepped on his..., well let it go at that. Bret Ludwig wrote: Introduction - Powerplant Choices RV aircraft are designed to use Lycoming aircraft engines. |
![]() Casey Wilson wrote: Any chance there's a point to this drivel? I found myself thinking the same thing Herr Ludwig didn't make it clear that he is ranting AGAINST the choice of the Lycoming for all RVs. How hard would it be to mount a Continental to an RV? I'm no A&P but how different could the mounts be for two engines of similar architecture? Do Cont. engines use four-point mounts like Lycs? |
![]() "Kingfish" wrote in message ups.com... Casey Wilson wrote: Any chance there's a point to this drivel? I found myself thinking the same thing Herr Ludwig didn't make it clear that he is ranting AGAINST the choice of the Lycoming for all RVs. How hard would it be to mount a Continental to an RV? I'm no A&P but how different could the mounts be for two engines of similar architecture? Do Cont. engines use four-point mounts like Lycs? Very different mounts. In addition, the 0-300 Continental is typically a 145 hp engine. Sure, it'll fly any of the 2 seat RV's, but *nobody* wants less power than the other guy, who is probably flying behind a 160 or 180 hp engine. In talking with Van's, they really thought they would have quite a few customers for the RV-9 who would use the 0-235 or 0-290. Sure, there are a few, but there are far more guys bolting on the 0-360 @ 180 hp, which is 20 hp more than what Van had in mind when he designed the airplane. KB |
![]() Kyle Boatright wrote: In talking with Van's, they really thought they would have quite a few customers for the RV-9 who would use the 0-235 or 0-290. Sure, there are a few, but there are far more guys bolting on the 0-360 @ 180 hp, which is 20 hp more than what Van had in mind when he designed the airplane. And now there's an O-340 out there that puts out 190 hp. Oh the choices. |
![]() "Newps" wrote in message . .. Kyle Boatright wrote: In talking with Van's, they really thought they would have quite a few customers for the RV-9 who would use the 0-235 or 0-290. Sure, there are a few, but there are far more guys bolting on the 0-360 @ 180 hp, which is 20 hp more than what Van had in mind when he designed the airplane. And now there's an O-340 out there that puts out 190 hp. Oh the choices. You're right, there are lots of choices. The O-340 as you mentioned, but also the O-390 and O-400, which are enlarged O-360's. Presumably all three of these engines will be relatively low volume. I'd be scared to death to buy one because if the Lyclone manufacturer who produces the oddball engine goes out of business, I don't think there will enough units in the field to drive anyone to support the engines. People with GO-300's, GO-470's, C-85's, O-290's and several other legacy powerplants are having problems getting parts for their engines. Those engines had much longer production runs than today's oddball lyclones are likely to see. KB |
In talking with Van's, they really thought they would have quite a few customers for the RV-9 who would use the 0-235 or 0-290. Sure, there are a few, but there are far more guys bolting on the 0-360 @ 180 hp, which is 20 hp more than what Van had in mind when he designed the airplane. That sounds a bit like the story of the RV-6. I thought it was originally intended for the O-320, and as more and more builders were apparently successful with O-360 installations, Van designed the RV-7 with that (among other changes) in mind. There is an old Tony Bingelis article about the pros and cons (mostly cons... weight, fuel flow) of bigger engines. Apparently a lot of RV builders missed that memo... ![]() basic design that it accepts increased power so well. I think RVs are great airplanes although I don't want one for my own. Apples and oranges thing I guess. |
Jim Carriere wrote:
That sounds a bit like the story of the RV-6. I thought it was originally intended for the O-320, and as more and more builders were apparently successful with O-360 installations, Van designed the RV-7 with that (among other changes) in mind. I built, own and still fly after 18 years the second customer built RV-6 and it has always been designed for an O-320 Or a O-360. Jerry |
Jerry Springer wrote:
Jim Carriere wrote: That sounds a bit like the story of the RV-6. I thought it was originally intended for the O-320, and as more and more builders were apparently successful with O-360 installations, Van designed the RV-7 with that (among other changes) in mind. I built, own and still fly after 18 years the second customer built RV-6 and it has always been designed for an O-320 Or a O-360. Hmmm, OK, was the -6 designed for the O-360 (to improve on the -4)? Or am I misinformed? |
![]() "Jim Carriere" wrote in message .. . Jerry Springer wrote: Jim Carriere wrote: That sounds a bit like the story of the RV-6. I thought it was originally intended for the O-320, and as more and more builders were apparently successful with O-360 installations, Van designed the RV-7 with that (among other changes) in mind. I built, own and still fly after 18 years the second customer built RV-6 and it has always been designed for an O-320 Or a O-360. Hmmm, OK, was the -6 designed for the O-360 (to improve on the -4)? Or am I misinformed? The RV-4 and RV-6 were designed for the 150-180 hp O (and IO) 320's and 360's.. Of course, clever builders started installing the angle valve IO-360, which is a 200 hp engine and is significantly heavier than the intended engines. So Van's introduced the RV-7 and RV-8 which are intended to use any of the 150-200 hp engines. Accordingly, clever builders are installing IO-390's and IO-400's, boosting compression, etc., so once again people are installing bigger, more powerful engines than Van intended. I think that if Van offered a PT-6 option, someone would want to shoehorn in the 15,000 hp Kuznetsov turbine liberated from a Tu-95 Bear bomber. KB |
![]() "Kyle Boatright" wrote In talking with Van's, they really thought they would have quite a few customers for the RV-9 who would use the 0-235 or 0-290. Sure, there are a few, but there are far more guys bolting on the 0-360 @ 180 hp, which is 20 hp more than what Van had in mind when he designed the airplane. I have a friend who was one of the few that chose the lower HP, then. He built a fire breathing, race 4.3 liter Chevy RV-7, then got it done and started almost immediately on a RV-9, which he put a 235 in. He claims that he can go blasting around in the 235 HP Chevy when he wants to go fast, and poke along in the O-235ci for trips, for next to nothing in gas costs. The best of both worlds! -- Jim in NC |
Zodiac XL vs Rans S-19 vs Van's RV-12 | Jim Logajan | Home Built | 12 | July 2nd 06 10:31 PM |
Very Nice Van's RV-6A For Sale | Don | Aviation Marketplace | 3 | January 14th 06 12:13 AM |
Very Nice Van's RV-6A For Sale | Don | General Aviation | 1 | December 21st 05 01:52 AM |
Vans RV-11 | Scott Correa | Soaring | 27 | January 5th 04 07:56 AM |
bulding a kitplane maybe Van's RV9A --- a good idea ????? | Flightdeck | Home Built | 10 | September 9th 03 07:20 PM |
