Hi,
I am looking for an Excel sheet or a dedicated program to generate flight envelopes. Please let me know if such exsists. Best regards |
Please define "flight envelopes".
I have a copy of a cross country planner designed in excel. BT "Michael Nyrup" aerosign-remove wrote in message ... Hi, I am looking for an Excel sheet or a dedicated program to generate flight envelopes. Please let me know if such exsists. Best regards |
With "Flight Envelope" I mean a pictorial way of displaying the strength of a plane. Load factor on the Y-axis and airspeed on X-axis. Va, Vne, Vd etc. is plotted and you get a graphical presentation of the plane limitations. I hope it is a little clearer... Best regards MN |
ok... that flight envelope..
I do not have a spreadsheet that would depict that for any given aircraft given certain input information... but I'm sure someone does B "Michael Nyrup" aerosign-remove wrote in message ... Please define "flight envelopes". With "Flight Envelope" I mean a pictorial way of displaying the strength of a plane. Load factor on the Y-axis and airspeed on X-axis. Va, Vne, Vd etc. is plotted and you get a graphical presentation of the plane limitations. I hope it is a little clearer... Best regards MN |
In article FO5Gg.269$8J2.6@fed1read11,
"BTIZ" wrote: ok... that flight envelope.. I do not have a spreadsheet that would depict that for any given aircraft given certain input information... but I'm sure someone does B "Michael Nyrup" aerosign-remove wrote in message ... Please define "flight envelopes". With "Flight Envelope" I mean a pictorial way of displaying the strength of a plane. Load factor on the Y-axis and airspeed on X-axis. Va, Vne, Vd etc. is plotted and you get a graphical presentation of the plane limitations. I hope it is a little clearer... I haven't made one for a year or two. It is called a V-n or V-g diagram. You can make it yourself. You look up all the information in the POH/AFM. Horizontal line is airspeed. Vertical line is g-loading. Top border is positive-g load limit. Bottom border is negative-g load limit. Right border is Vne. Left border is Zero kts/mph. The positive knee is at Va, Vs is another point at 1-g. I would have to go back and review my sources, but this is what I recall from memory. I asked Cessna and Piper for the diagrams they generate based on flight test data, but they would not provide it. |
Here's a "Flight Envelope" one of my buddies is working on:
http://www.personalblimp.com/index.html See ya, Dave BTIZ wrote: Please define "flight envelopes"... |
It is called a V-n or V-g diagram. You can make it yourself. You look up all the information in the POH/AFM. Horizontal line is airspeed. Vertical line is g-loading. Top border is positive-g load limit. Bottom border is negative-g load limit. Right border is Vne. Left border is Zero kts/mph. The positive knee is at Va, Vs is another point at 1-g. I would have to go back and review my sources, but this is what I recall from memory. I asked Cessna and Piper for the diagrams they generate based on flight test data, but they would not provide it. I too have made a few by hand but its never as nice as it would be if generated by excel or similar. |
Michael Nyrup wrote:
I haven't made one for a year or two. It is called a V-n or V-g diagram. You can make it yourself. You look up all the information in the POH/AFM. Horizontal line is airspeed. Vertical line is g-loading. Top border is positive-g load limit. Bottom border is negative-g load limit. Right border is Vne. or Vd, if used for design and load calculations Left border is Zero kts/mph. The positive knee is at Va, Vs is another point at 1-g. I would have to go back and review my sources, but this is what I recall from memory. I asked Cessna and Piper for the diagrams they generate based on flight test data, but they would not provide it. I too have made a few by hand but its never as nice as it would be if generated by excel or similar. and don't forget to consider gust loads. john described the manoevring envelope which is only part of the flight envelope. michael: for which purpose do you need the envelope? if you just want to create a placard for your cockpit, refer to the POH; there you should find any information needed. if you want to design a new airplane, refer to the applicable certification specification which describes the flight envelope pretty well (CS-22 in europe). uli |
create a placard for your cockpit, refer to the POH; there you should find any information needed. if you want to design a new airplane, refer to the applicable certification specification which describes the flight envelope pretty well (CS-22 in europe). No I am not designing an airplane :-) I just want to have the envelopes with me and be able to compare them between types. No problem, I can do it by hand, it's just had been easier (and nicer) to enter the data and have it plotted automatically. Regards Michael |
RAF Blind/Beam Approach Training flights | Geoffrey Sinclair | Military Aviation | 3 | September 4th 09 06:31 PM |
Dumb Reg question | John Gaquin | Piloting | 67 | May 4th 05 04:54 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
