Greg Farris wrote:
In article , says... Matt Whiting wrote: It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. In theory, it should be possible on any plane. 14 CFR 23.677 (d) says: Say that to the 130 souls who perished in the B-707 accident on takeoff from Paris' Orly airport, due to an out-of-trim condition. http://aviation-safety.net/database/...0603-0&lang=en The fact that the pilot didn't fly the airplane to its capability doesn't mean the capability isn't there. Matt |
![]() "Greg Farris" wrote Say that to the 130 souls who perished in the B-707 accident on takeoff from Paris' Orly airport, due to an out-of-trim condition. It is really easy to sit back and say that the accident was easily preventable, but in truth, it probably was easily preventable. Problem number one, in the chain of the accident events, was the failure of the trim motor. Number two, was the failure of the flight crew to recognize that the trim was not in the correct place. Number three, and the final link in the chain, was the failure of the flight crew to continue with the takeoff, when there was insufficient distance in which to stop the aircraft. If the takeoff had continued, the certification standards say that a successful takeoff was still possible. In a fraction of a second, the flight crew made the wrong choice, because there was not enough distance remaining to successfully abort the takeoff. They, and their charges, paid for the mistake with their lives. The final link in the chain was not broken. Sad, but mistakes (pilot error) still happen. -- Jim in NC |
Greg Farris wrote:
In article , says... Matt Whiting wrote: It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. In theory, it should be possible on any plane. 14 CFR 23.677 (d) says: Say that to the 130 souls who perished in the B-707 accident on takeoff from Paris' Orly airport, due to an out-of-trim condition. http://aviation-safety.net/database/...0603-0&lang=en The B707 was not certified per 14 CFR 23. (It was most likely certified under 14 CFR 25 or its predecessor). I assume the earlier poster's "any plane" before he mentioned meant 14 CFR 23.677 (d) "any plane certified under 14 CFR 23. YMMV. |
Roy Smith wrote:
Matt Whiting wrote: It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. In theory, it should be possible on any plane. 14 CFR 23.677 (d) says: "It must be demonstrated that the airplane is safely controllable and that the pilot can perform all maneuvers and operations necessary to effect a safe landing following any probable powered trim system runaway that reasonably might be expected in service, allowing for appropriate time delay after pilot recognition of the trim system runaway. The demonstration must be conducted at critical airplane weights and center of gravity positions." Like they say, in theory there is no difference between theory and practice, in practice there is. :-) I've never flown an airplane where this wasn't the case, but then I've flown fewer than a dozen different airplanes so I was hesitant to say all. Matt |
![]() "Matt Whiting" wrote in message ... Roy Smith wrote: Matt Whiting wrote: It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. In theory, it should be possible on any plane. 14 CFR 23.677 (d) says: "It must be demonstrated that the airplane is safely controllable and that the pilot can perform all maneuvers and operations necessary to effect a safe landing following any probable powered trim system runaway that reasonably might be expected in service, allowing for appropriate time delay after pilot recognition of the trim system runaway. The demonstration must be conducted at critical airplane weights and center of gravity positions." Like they say, in theory there is no difference between theory and practice, in practice there is. :-) I've never flown an airplane where this wasn't the case, but then I've flown fewer than a dozen different airplanes so I was hesitant to say all. In the Lear 24B, this would be a very close thing. In a normal landing, the trim is run almost completely nose up. An attempted departure at this setting will get an extreme pitch up starting at about 80 knots, with little warning in advance. It is possible to control the aircraft, but you will be pushing with more than 50lbs. Depending on the airspeed you let build, it may take both pilots. Obviously retrimming is your first option, but if you departed with the electric trim inop or shut off(there is a switch), retarding the throttles or a very steep bank are your only options to maintain control. There is no manual trim wheel. The requirement for trim is massive as speed builds, which it does very quickly. Al G |
On Sun, 27 Aug 2006 18:44:30 GMT, Matt Whiting
wrote in : Larry Dighera wrote: On 27 Aug 2006 08:39:44 -0700, wrote in . com: I was mentioning how illogical a crash-shortly-after-takeoff is, given that beyond V1 takeoff can safely be continued even with just one good engine. I once witnessed a Cessna C-172 crash on takeoff at Santa Monica Airport (KSMO) in the early '70s. The aircraft rotated, and rocketed skyward at a very high angle, stalled, and nosed into the runway. The pilot escaped with a broken finger. The cause was a result of the trim being set wrong. Don't forget your check list. I'd say in a 172 that the cause was a pilot who didn't know how to fly the airplane. It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. I'd say you are right. Here's the (poorly formatted) NTSB report: http://www.ntsb.gov/ntsb/brief.asp?ev_id=44872&key=0 NTSB Identification: LAX75FUD03 14 CFR Part 91 General Aviation Event occurred Monday, December 30, 1974 in SNTA MONICA, CA Aircraft: CESSNA 172M, registration: N13723 ---------------------------------------------------------------------------------------------------------------------------- FILE DATE LOCATION AIRCRAFT DATA INJURIES FLIGHT PILOT DATA F S M/N PURPOSE----------------------------------------------------------------------------------------------------------------------------3-4024 74/12/30 SNTA MONICA,CALIF CESSNA 172M CR- 0 0 1 INSTRUCTIONAL STUDENT, AGE 45, 21 TOTAL TIME - 1649 N13723 PX- 0 0 0 SOLO HOURS, ALL IN TYPE, NOT DAMAGE-SUBSTANTIAL OT- 0 0 0 INSTRUMENT RATED. NAME OF AIRPORT - SANTA MONICA DEPARTURE POINT INTENDED DESTINATION SNTA MONICA,CALIF LOCAL TYPE OF ACCIDENT PHASE OF OPERATION STALL TAKEOFF: INITIAL CLIMB PROBABLE CAUSE(S) PILOT IN COMMAND - IMPROPER OPERATION OF FLIGHT CONTROLS PILOT IN COMMAND - FAILED TO OBTAIN/MAINTAIN FLYING SPEED FACTOR(S) PILOT IN COMMAND - LACK OF FAMILIARITY WITH AIRCRAFT MISCELLANEOUS ACTS,CONDITIONS - TOUCH AND GO LANDING REMARKS- SECOND SOLO FLT. |
Matt Whiting wrote:
You are assuming that all such crashes are due to partial power loss. Isn't so. One airplane crash on takeoff a few years ago was due to a problem with the elevator trim, if I recall correctly. Also, a weight and balance issue can cause a crash right after takeoff as can myriad other problems not related to power. Well, why then do you guys dread an engine failure more than anything else? ![]() your control - pitch trim, aircraft loading, choice of runway, condition of the tires and whatever else. Engines too I'm sure aren't altogether iffy but there's an element of risk of a failure because of their enormous complexity - and nobody can deny that there isn't anything simple about a turbine! Someone on this thread mentioned 'loss of control surfaces' as one of the many possible reasons - what does that mean? A hydraulic failure that altogether prevents aileron, elevator and rudder control? Ramapriya |
else? ![]() Because most of the time, if we have an engine failure it's because we put too much air in the tanks, and that's a pretty embarassing mistake. ![]() Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Approaches and takeoff mins. | jamin3508 | Instrument Flight Rules | 22 | September 14th 05 02:51 AM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 3rd 03 11:53 PM |
