Approaches and takeoff mins.
Old September 9th 05, 02:41 PM
jamin3508
Default Approaches and takeoff mins.
Today I awoke to find a cloud sitting on the ground bringing the vis down
to 1/16th of a mile. All the airlines here in KROC were forced to hold
from takeoff until it lifted a little. I know that the part 91 is 0/0
unless otherwise noted, what about part 131 or the airlines? Do they have
different takeoff mins? My next question is about the approach to
landing....if the wx during the landing was like this morning right, below
mins for sure (1/16th SM VV100), could a part 91 still attempt the approach
hopeing the was a hole in the scud and see the runway, but knowing its
below mins and will most likely go missed? What about the airlines and air
carriers, could they attempt the approach when the wx is below mins? I
guess what Im trying to ask is.....anyone allowed to attempt a approach
when the wx is below mins? What if the field is uncontrolled with an ILS
and does have AWOS reporting below mins. Does is matter if its controlled
or not? Im just wondering about this, dont get me wrong, I would NEVER
attempt a approach thats below mins. Just courious if its stated somewhere
in the FARS (I couldnt find it) about the approach to landing with below
mins WX.....thanks for the imput!
-Ben
Old September 9th 05, 03:09 PM
Dave Butler
I couldn't find Part 131. If you mean parts 121 and 135, yes their rules are
different.
Do they have
Part 121/135 operators can't accept an approach clearance if the reported
weather is below minimums. "see the runway" is not sufficient for Part 91, either.
No.
I
Part 91.
or not?
No.
Why wouldn't you? Are you operating under Part 121/135?
Old September 9th 05, 03:21 PM
Garner Miller
In article
outaviation.com,
Part 121, I assume you mean, and yes, they have different takeoff mins.
At my company, we basically use the minimums on the Jeppesen charts.
It depends how the runway is equipped, but normally we need 1600RVR
(1/4mi) on a runway with standard takeoff minimums and adequate visual
references. In many places, we can take off with as low as 600 RVR,
but that requires multiple RVR sensors and a runway with centerline
lights. (Some operators can use 500RVR; 600 is as low as we can go.
It's in each specific airline's FAA ops specs.)
Sticky area. You can definitely shoot the approach, but landing from
it could be problematic. The rules say "flight visibility," which you
can only really judge in-flight. Tower visibility really isn't a good
indicator of flight visibility, but RVR is a much more accurate view of
what you'll probably see from the cockpit.
I understand they *have* hung pilots out to dry for landing with RVR
below minimums. I don't have a specific cite for that, so it may be
urband legend. Perhaps someone can chime in on this one?
No. If the visibility/RVR is below approach minimums, an air carrier
can't continue past the final approach point; he'd have to go missed at
that point if there wasn't a report of the visibility being at or above
the minimum. If touchdown zone RVR is available, it's the controlling
value that decides whether they can start the approach. If not, it's
visibility.
If they're already on the final approach segment and the visibility/RVR
goes down, they may continue the approach, but as far as landing goes,
we're back to "flight visibility." If the RVR is below minimums,
you're not likely to see the visual cues you need anyway. I'd continue
the approach and hope the reported RVR comes back up before DH, but a
missed approach is most likely at that point.
I guess what Im trying to ask is.....anyone allowed to attempt a approach
Yes, part 91 operators are completely free to attempt the approach, at
least down to DH.
or not?
No, it doesn't matter. It's the only reported weather, which means if
it's reporting visibility below minimums, an air carrier can't fly the
approach. My company serves a couple of uncontrolled airports, and we
run into that from time to time. But a part 91 aircraft can start the
approach, definitely.
At an uncontrolled airport with an AWOS reporting below minimums, I'd
absolutely try the approach under part 91, because the visibility of an
AWOS is not often a good indicator of what you'll see. Flight
visibility may be just fine on the runway, often because it's on a
different part of the airport from the AWOS visibility measurement.
I've often seen a fog bank covering just half an airport, leaving most
of my landing runway completely clear.
The specific FAR is 91.175. It says an aircraft may not descent below
DH/MDA unless, among other things, "The flight visibility is not less
than the visibility prescribed in the standard instrument approach
being used." But it says nothing about *starting* the approach;
that's specific to air carrier operations. You're perfectly legal to
fly the approach; you just need to meet that reg in order to continue
past the bottom of the approach.
Hope that hhelps.
Garner R. Miller
ATP/CFII/MEI
Clifton Park, NY =USA=
Old September 9th 05, 08:07 PM
Robert M. Gary
I've shot approaches below minimums many times. I fly down to the fog
valley when vis is 0/0 and just shot approaches. Its good practice.
If you actually land and the approach calls for both a flight
visibility minimum AND lists an RVR minimum you could probably get in
trouble for landing when the RVR is reported below those mins.
-Robert
Old September 9th 05, 09:52 PM
Paul Lynch
One addition to other posters comments on going below DH. You can go below
DH without having the runway in sight if you have the runway environment
(approach lighting system) is sight. You are authorized (91 and 135) to 100
feet. At 100 feet you must have the runway (which can mean only the end
lights of the runway) in sight.
Our FSDO operations inspector wants us to set 100 feet on the radar
altimeter because that is the absolute lowest you can go on a typical
approach. Many pilots prefer the DH AGL altitude set on the radalt.
Paul
"jamin3508" wrote in message
lkaboutaviation.com...
approach
-Ben
Old September 9th 05, 09:56 PM
Stan Gosnell
lkaboutaviation.com:
just wondering about this, dont get me wrong, I would NEVER attempt a
approach thats below mins. Just courious if its stated somewhere in
Part 135 and Part 121 takeoff and landing minima are given in the
operations specifications of each certificate holder. Generally the
approach minima are whatever is published, but it can vary. Our ops
specs permit flying an ILS with 1/4 mile vis (in helicopters) and
takeoffs with 'adequate visibility reference' from a runway, meaning with
whatever visibility allows seeing the runway during the takeoff. It's
generally higher for airplanes. We can take off with 1/2 mile vis from
offshore platforms, and fly the approach with 3/4 mile vis. We also
cannot fly an approach to any airport that does not have official weather
reporting, regardless of the weather.
Regards,
Stan
"They that can give up essential liberty to obtain a little temporary
safety deserve neither liberty nor safety." B. Franklin
Old September 9th 05, 10:40 PM
Bob Moore
below DH without having the runway in sight if you have the runway
environment (approach lighting system) is sight. You are authorized
(91 and 135) to 100 feet. At 100 feet you must have the runway (which
can mean only the end lights of the runway) in sight.
I don't think that you fully understand 91.175....
(3) Except for a Category II or Category III approach where any
necessary visual reference requirements are specified by the
Administrator, at least one of the following visual references for the
intended runway is distinctly visible and identifiable to the pilot:
(i) The approach light system, except that the pilot may not descend
below 100 feet above the touchdown zone elevation using the approach
lights as a reference unless the red terminating bars or the red side
row bars are also distinctly visible and identifiable.
(ii) The threshold.
(iii) The threshold markings.
(iv) The threshold lights.
(v) The runway end identifier lights.
(vi) The visual approach slope indicator.
(vii) The touchdown zone or touchdown zone markings.
(viii) The touchdown zone lights.
(ix) The runway or runway markings.
(x) The runway lights.
It says that I can go below 100' on the approach lights only, if I
have either the red terminating bars or red side row bars visible.
The 100' limit is not applicable if I have any of the items (ii)
thru (x) in sight, ie, I can descend below DH with only the VASI
in sight or...the REILS for that matter.
Bob Moore
ATP CFI
PanAm (retired)
Old September 9th 05, 11:47 PM
Paul Lynch
I guess I miss your point Bob. I don't think I said anything that conflicts
with 91.175. I am ready to be educated, for me that process is painfully
endless.
"Bob Moore" wrote in message
. 122...
(ii) The threshold.
Bob Moore
ATP CFI
PanAm (retired)
Old September 10th 05, 12:07 AM
Bob Moore
conflicts with 91.175. I am ready to be educated, for me that process
is painfully endless.
Well....you said:
" At 100 feet you must have the runway (which can mean only the end
lights of the runway) in sight."
I mearly pointed out that you do not have to have the runway (nor the
end lights of the runway) in sight. The Touchdown Zone Markings will do
quite well as will the VASI and obviously... the Runway Markings.
Bob Moore
Old September 10th 05, 02:08 AM
Ron Rosenfeld
On Fri, 09 Sep 2005 20:40:16 GMT, Bob Moore
(ii) The threshold.
Bob Moore
ATP CFI
PanAm (retired)
And don't forget 91.175(c)(2) which says that in order to operate below DH,
you ALSO need to have "the visibility prescribed in the standard instrument
approach being used".
My Approach and takeoff Videos A Lieberman Instrument Flight Rules 0 April 16th 05 05:50 AM
Why fly fast approaches? EDR Piloting 54 July 8th 04 02:20 AM
FS2004 approaches, ATC etc henri Arsenault Simulators 14 September 27th 03 01:48 PM
