Bill Daniels wrote: Is it legal/possible/reasonable to install just Mode A transponder (No altitude reporting)? Whenever I hear "Traffic 12 O-clock 3 miles, altitude unknown" I look EVERYWHERE. ahead. Might this provoke more visual scanning by aircraft crews which could spot gliders without transponders in the same gaggle? A case of one protecting all? As a side benefit this would avoid the 24 months Mode C altimeter/encoder check. Bill Daniels Sure, anything is possible/ and/or reasonable. As far as legal goes, remember if you have an instrument of any kind installed, you are required by regulation to have it signed off by an A/P in your aircraft log book. Additionally some reference to weight and bal. should also be noted even if it's only to say, "no significant weight change." If you put a transponder in your glider - either with or without an encoder - it needs to be calibrated and so noted in your aircraft log book. You are then required to have checked every twenty-four months. If you are going to put a transponder in the glider, then spring for an encoder - In for a penny, in for a pound and all that. Without the encoder ATC as well as TCAS only gets azimuth and range. With the encoder you get the third demension, altitude. Sure beats ending up in Denver as a pitot cover on a B-767! Billy Hill, Zulu |
| Thread Tools | |
| Display Modes | |
| Thoughts on Oshkosh | Jim Carter | Piloting | 0 | August 1st 06 09:26 PM |
| Engine stumble, Any thoughts? | Dave | Owning | 21 | December 7th 05 01:43 AM |
| further thoughts about women suicide bombers | Cub Driver | Military Aviation | 24 | January 18th 04 08:52 AM |
| Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 05:21 PM |
| Thoughts at a funeral for a stranger | matheson | Military Aviation | 2 | July 4th 03 06:27 AM |
