Thomas Borchert writes:
No. But who cares - you're not flying, you're simming. The whole idea of simulation is to approach real life, whence the name. For landing, you don't want to accidentally touch the wrong switch while in a hurry on the runway (e.g. the gear switch - happens often). Your primary concern is to get off the runway. After that, stop and complete the after landing checklist, which includes flaps. Do aircraft commonly have mechanisms to prevent gear retraction when the wheels are touching ground, or is it usually up to the pilot not to do anything unwise? Your stall speed is reduced by the flaps by maybe 10 or 20 knots. If the wind is blowing enough for your stall speed to be a factor - don't fly. I was under the impression that full flaps is a normal configuration for landing; is this not true? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Squat switches of some type are common on all retractable
gear airplanes built since WWII. But they can fail for several reasons. Some airplanes have a squat switch on only one gear strut, later models of the same aircraft often added a second squat switch. A gentle landing with an over-inflated strut might not compress the strut enough to activate the switch (open) or a bump can allow the strut to re-extend. Most gear up landings are just that, the pilot did not put the gear down. But gear can be retracted while on the ground if the airplane has the right combination of "problems" such as over-inflated struts, shorted squat switches, hydraulic problems, , etc. "Mxsmanic" wrote in message ... | Thomas Borchert writes: | | No. But who cares - you're not flying, you're simming. | | The whole idea of simulation is to approach real life, whence the | name. | | For landing, you don't want to accidentally touch the wrong switch | while in a hurry on the runway (e.g. the gear switch - happens often). | Your primary concern is to get off the runway. After that, stop and | complete the after landing checklist, which includes flaps. | | Do aircraft commonly have mechanisms to prevent gear retraction when | the wheels are touching ground, or is it usually up to the pilot not | to do anything unwise? | | Your stall speed is reduced by the flaps by maybe 10 or 20 knots. If | the wind is blowing enough for your stall speed to be a factor - don't | fly. | | I was under the impression that full flaps is a normal configuration | for landing; is this not true? | | -- | Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: Thomas Borchert writes: No. But who cares - you're not flying, you're simming. The whole idea of simulation is to approach real life, whence the name. Do you guys do simulated ramp checks? |
Roy Smith wrote:
In article , Mxsmanic wrote: Thomas Borchert writes: No. But who cares - you're not flying, you're simming. The whole idea of simulation is to approach real life, whence the name. Do you guys do simulated ramp checks? I have read of many sim pilots actually drinking alcohol while they fly, too. -- Peter |
Peter R. wrote:
I have read of many sim pilots actually drinking alcohol while they fly, too. Count me as one. I damn near fell out of the chair after too many Sierra Nevada Pale Ales while flying MSFS. |
("B A R R Y" wrote)
I have read of many sim pilots actually drinking alcohol while they fly, too. Count me as one. I damn near fell out of the chair after too many Sierra Nevada Pale Ales while flying MSFS. Click on the "Fasten Seat Belt" switch, after your 4th SNPA, and that wouldn't happen as often. Montblack |
Roy Smith writes:
Do you guys do simulated ramp checks? All sim users are not identical, but it certainly would not surprise me if some of them are simulating ramp checks, as well as many other aspects of real-world bureaucracy. Different people are interested in different aspects of real-world aviation, and simulation generally allows them to concentrate on the aspects that interest them most, while letting the rest slide. In theory just about anything can be simulated. I personally avoid the paperwork. Sim software itself often makes no significant provision for paperwork, beyond things like checklists and the like, so anyone wanting the paperwork side has to pretend on his own. MSFS allows you to file a "flight plan" for IFR flights and simulates ATC interaction based on the flight plan, but it doesn't go much beyond that. Fortunately for me, that's about as far as I'm interested in going myself. The simulated ATC is limited in what it can handle and varies from reality in a number of ways, and it sometimes makes stupid mistakes, but it still enhances realism a great deal. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Roy Smith wrote:
Do you guys do simulated ramp checks? How about a simulated IMSAFE or bottle to throttle? G |
![]() I wonder if there's a simulated mile high club? Simulator pilots can pretend to have a date! G |
Mxsmanic wrote:
Thomas Borchert writes: No. But who cares - you're not flying, you're simming. The whole idea of simulation is to approach real life, whence the name. For landing, you don't want to accidentally touch the wrong switch while in a hurry on the runway (e.g. the gear switch - happens often). Your primary concern is to get off the runway. After that, stop and complete the after landing checklist, which includes flaps. Do aircraft commonly have mechanisms to prevent gear retraction when the wheels are touching ground, or is it usually up to the pilot not to do anything unwise? Your stall speed is reduced by the flaps by maybe 10 or 20 knots. If the wind is blowing enough for your stall speed to be a factor - don't fly. I was under the impression that full flaps is a normal configuration for landing; is this not true? My primary flight instructor had a great saying "Do whatever it takes". If you are flying into a short field with minimal wind full flaps would make sense. If you are flying into a long, high-speed runway (like Dulles or something) a no flap landing can be used. If the wind is really squirrly you might want partial flaps. Now, what flap setting is "normal" full flaps. I flew a 172 with 40 degrees of flaps, so is 30 degrees "full flaps"? What if that's all your 172 has? The Navion has more than 40 degrees, do I need all of that flap? It depends! (BTW with the old engine take-off in the Navion was 0 flaps, with the new engine it's half-flaps). Margy I have a great idea, why don't you get a few hours in a "real" airplane. |
