Doug writes:
If you have to have a fuel pump, then usually you have two, so you have a backup if one quits. As for the mixture, that is very important and often used. Most systems now have an EGT (exhaust gas temp) guage and you use that temperature to set the mixture. There is also a procedure for setting the mixture based on rpm. At altitudes above 3000' (some use 5000), the mixture is set leaner than full rich on the ground before takeoff at runup. How do I determine how much actual propulsive thrust I'm generating? I see a throttle setting, manifold pressure, RPM, and pitch, but I'm not sure how to set all this in order to increase or decrease total thrust. I've been reading the FAA's handbook, but I'm still not very clear on how it works. My _impression_ is that I advance throttles to provide more power, and then set propeller pitch to the green range in order to translate engine power into optimum thrust. Is that right? But apparently manifold pressure is supposed to be telling me something, too. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Piston engines use percent power. So if you want to cruise at 65% power
(and burn fuel at the rate stated for that power setting), you look in the aircraft manual for the rpm setting and manifold setting that gives 65% power (there may be more than one). For any given percent power, you will get better fuel economy if you use the lower rpm and higher manifold pressure setting. (This is akin to going up a hill in a car in a high gear and full throttle. Such procedure uses less fuel than downshifting and using say, 3/4 throttle). There is no percent power guage that gives a direct measure of the engines output. You can also derive percent power from fuel burn if you have an accurate fuel flow meter. The rule of thumb is 12 horsepower per gallon per hour. So if you are burning 12 gallons an hour that is 120 horsepower. If the engine's max horsepower is 180 then you are at 120/180 percent power. Things like this give pilots on long flights something to do.... Thrust is something a little different. Airplanes with jet engines use thrust (whose unit is pounds) for their power settings, I believe. I'm no expert though. I do know you don't use thrust for small gasoline driven prop engines like in Cessnas and Pipers. |
![]() Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. |
I'd never heard of these, but, right you are! Check out
http://www.jpinstruments.com/edm_700.html Quite the guage! Newps wrote: Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. |
Newps wrote: Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. I suppose it depends on what you mean by "direct measure". Power delivered by a rotating shaft is RPM * Torque. RPM is easy to measure directly, torque is somewhat more difficult. In any case, the JPI gizmo doesn't measure torque. It measures manifold pressure, and fuel flow, and intake air temperature, and maybe a few other things, and computes how much power the engine must be delivering based on those inputs. That's not quite the same thing as measuring the output directly. I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". |
![]() Roy Smith wrote: In article , Newps wrote: Doug wrote: There is no percent power guage that gives a direct measure of the engines output. Sure there is. JPI has one in their engine monitors. There are others. I suppose it depends on what you mean by "direct measure". Power delivered by a rotating shaft is RPM * Torque. RPM is easy to measure directly, torque is somewhat more difficult. In any case, the JPI gizmo doesn't measure torque. It measures manifold pressure, and fuel flow, and intake air temperature, and maybe a few other things, and computes how much power the engine must be delivering based on those inputs. That's not quite the same thing as measuring the output directly. I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". As long as it's accurate, who cares? |
![]() "Newps" wrote: I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". As long as it's accurate, who cares? I would not accept as accurate a calculation that leaves out essential parameters. It's an educated guess. -- Dan C172RG at BFM |
![]() Dan Luke wrote: "Newps" wrote: I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". As long as it's accurate, who cares? I would not accept as accurate a calculation that leaves out essential parameters. It's an educated guess. No, it's either accurate or it's not. Compare what the JPI says to what the chart in the POH says. If it's accurate then it is irrelavant how it got the information. |
"Newps" wrote in message
... [...] I'm not saying that what the JPI does isn't useful. Just that it doesn't fit my definition of "direct measure". As long as it's accurate, who cares? It's only accurate when the engine is performing according to its design. So I'd say any pilot using that sort of "power monitor" should care. It's not a means for verifying actual power output of the engine. It's little more than an electronic handbook translating the POH power charts to a graphic real-time display. Which is not to say it's not useful. I'd say it certainly is. But it's VERY important to understand what it is and what it's not. Any pilot who doesn't care is likely to wind up in the trees one day, trusting the display too much. Pete |
The PT6 engine measures torque, which is shown in ft.lbs,
although the higher rated engines often use percent. Measuring torque cost money, it isn't "cost effective" on low powered engines. "Roy Smith" wrote in message ... | In article , | Newps wrote: | | Doug wrote: | | | There is no percent power guage that gives a direct measure of the | engines output. | | | Sure there is. JPI has one in their engine monitors. There are others. | | I suppose it depends on what you mean by "direct measure". | | Power delivered by a rotating shaft is RPM * Torque. RPM is easy to | measure directly, torque is somewhat more difficult. In any case, the JPI | gizmo doesn't measure torque. It measures manifold pressure, and fuel | flow, and intake air temperature, and maybe a few other things, and | computes how much power the engine must be delivering based on those | inputs. That's not quite the same thing as measuring the output directly. | | I'm not saying that what the JPI does isn't useful. Just that it doesn't | fit my definition of "direct measure". |
Exposed Electrical Wires in Boeing 737 Fuel Tanks! | Larry Dighera | Piloting | 0 | July 17th 06 06:13 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
C-172 Fuel | [email protected] | Piloting | 23 | November 23rd 05 09:39 PM |
More long-range Spitfires and daylight Bomber Command raids, with added nationalistic abuse (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 161 | September 25th 03 07:35 AM |
First flight tests of systems to mitigate fuel tank explosions | Peter Duniho | Piloting | 1 | July 16th 03 10:49 PM |
