I did a 200 km flight today (my personal best) that I wanted to post to
the OLC. The OLC site refuses to accept the trace, stating that "the maximum timegap between two valid fixes is too large. (2166 sec 900 sec)". I am instructed to correct the error, and then click 'check entry'. Obviously, any such a "correction" will cause the flight to fail a security check. Yet without the correction, I can't post the flight at all. Catch 22... The flight was recorded using a Cambridge GPS-NAV Model 25. I'm told that sometimes a bad time value is inserted into the data file with this recorder. What galls me is that SeeYou has no problem presenting the flight trace, but the OLC software can't! Does anyone have any suggestions? Probably it's too late to do anything, since the Tuesday midnight deadline is almost here (another Catch 22). -John |
jcarlyle wrote:
I did a 200 km flight today (my personal best) that I wanted to post to the OLC. The OLC site refuses to accept the trace, stating that "the maximum timegap between two valid fixes is too large. (2166 sec 900 sec)". I am instructed to correct the error, and then click 'check entry'. Obviously, any such a "correction" will cause the flight to fail a security check. That's a common misconception. The .igc files from the GPS-NAV models have absolutely no security in them at all. Editing the file, then repackaging it with the .cai file might be possible, but messy. Yet without the correction, I can't post the flight at all. Catch 22... The flight was recorded using a Cambridge GPS-NAV Model 25. I'm told that sometimes a bad time value is inserted into the data file with this recorder. What galls me is that SeeYou has no problem presenting the flight trace, but the OLC software can't! Does anyone have any suggestions? Probably it's too late to do anything, since the Tuesday midnight deadline is almost here (another Catch 22). Do the start and end of soaring flight times look correct? It's possible the problem is before or after the actual flight. Sometimes you have to adjust those manually to deal with noise during landing or whatever. -Dave -John |
jcarlyle wrote:
I did a 200 km flight today (my personal best) that I wanted to post to the OLC. The OLC site refuses to accept the trace, stating that "the maximum timegap between two valid fixes is too large. (2166 sec 900 sec)". I am instructed to correct the error, and then click 'check entry'. Obviously, any such a "correction" will cause the flight to fail a security check. Yet without the correction, I can't post the flight at all. Catch 22... You have a week to post (see below), so you have time to ask the OLC guys to fix your file. Or you could convert to IGC format, then erase the bogus line. This should pass OLC "security" (very limited if any security for Model 25 files). The flight was recorded using a Cambridge GPS-NAV Model 25. I'm told that sometimes a bad time value is inserted into the data file with this recorder. What galls me is that SeeYou has no problem presenting the flight trace, but the OLC software can't! The Model 20 and 25 seem to insert bogus values from time to time. Does anyone have any suggestions? Probably it's too late to do anything, since the Tuesday midnight deadline is almost here (another Catch 22). Since the flight was on Tuesday, you have until next Tuesday to post the flight. -John |
I tried to fix your claim, but the IGC file you submitted has no
G-record. I'm not sure how you created it, but the easiest way is to use an automated software tool. See the following notes for help with this: # If you are using a Cambridge GPS-NAV Model 10/20/25 logger, with SeeYou flight analysis software, you should use SeeYou v3.5 or later for reliable claim processing. # If you are using a Cambridge GPS-NAV Model 10/20/25 logger with SeeYou or StrePla flight analysis software, you must use the original *.CAI file to generate the OLC flight claim. The software will automatically convert this to *.IGC and properly append the binary data for validation. Do not convert the *.CAI to *.IGC outside these programs. # If you are using a Cambridge GPS-NAV Model 10/20/25 logger, without SeeYou or StrePla, you will need to convert the *.CAI file to *.IGC and append the binary data. Carl Ekdahl has written a freeware utility CAI2IGC4OLC to automate the process described above. See: http://www.abqsoaring.org/misc_files/CAI_fix.htm To correct your claim, you will have to resubmit the IGC file to OLC. To force the server to revalidate your claim, increase the last digit of your filename by one. If you need additional help, send me your CAI file by private email. Doug Haluza SSA-OLC Admin David Walsh wrote: John, Try sending an email to They are very helpful and submitted flights on my behalf for most of this year. As DBA's they can easily get around the Tuesday midnight deadline. 200 km is worth fighting for. Congrats and good luck! Regards, David Walsh jcarlyle wrote: I did a 200 km flight today (my personal best) that I wanted to post to the OLC. The OLC site refuses to accept the trace, stating that "the maximum timegap between two valid fixes is too large. (2166 sec 900 sec)". I am instructed to correct the error, and then click 'check entry'. Obviously, any such a "correction" will cause the flight to fail a security check. Yet without the correction, I can't post the flight at all. Catch 22... The flight was recorded using a Cambridge GPS-NAV Model 25. I'm told that sometimes a bad time value is inserted into the data file with this recorder. What galls me is that SeeYou has no problem presenting the flight trace, but the OLC software can't! Does anyone have any suggestions? Probably it's too late to do anything, since the Tuesday midnight deadline is almost here (another Catch 22). -John |
The BIGGER problem in the FAA exposed | JohnWayne | Instrument Flight Rules | 4 | September 2nd 06 11:21 PM |
RF interference issue again (esp. for E Drucker and Jim Weir and other RF wizards) | Snowbird | Home Built | 78 | December 3rd 03 09:10 PM |
Garmin fixes moving waypoint problem -- almost | Jon Woellhaf | Instrument Flight Rules | 6 | November 28th 03 05:29 PM |
Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 02:31 PM |
fatal bird strike | StellaStar | Piloting | 9 | July 13th 03 09:41 PM |
