Landing on a sloping runway with different wind velocities
Old October 9th 06, 10:33 PM posted to rec.aviation.piloting
Jim Macklin
Default Landing on a sloping runway with different wind velocities
A downwind take-off into higher terrain is a bad thing.
There are no hard and fast rules. With a landing on a
one-way runway or with a tailwind, there will be a point at
which a go-around can be made safely and once you are below
that point, a landing is your only option. That's why
mountain and hill flying is a challenge
"Tony Cox" wrote in message
| Here's a problem which seems to have a non-trivial
solution.
| At least, I've not been able to find a definitive answer
to it, but
| what do I know??
| Suppose one wishes to land at an airport with a runway
| that slopes at X degrees. The wind -- assumed to be
directly
| aligned with the runway -- is Y knots from the "high" end
of
| the runway.
| Clearly, if Y is positive, one should try to land in the
| "up-slope" direction to minimize one's ground roll. One
| will be landing "up" and into a headwind. But what if
| Y is negative? Clearly, if Y is just a few knots neg, one
would
| still land "up-slope", because the braking effect of
rolling
| out up-hill more than compensates for the higher landing
| speed due to the tail wind.
| If Y is negative and more substantial, which way should
| one land? At some point, it makes sense to switch to the
| other end of the runway -- landing downhill -- to take
advantage
| of the (now) headwind. But how does one establish which
way
| to land, assuming no clues from other traffic in the
pattern? The
| aim is to select a direction, given X and Y, which would
result
| in the smaller ground roll.
| Rule of thumb responses are interesting, but better would
be
| a full mathematical treatment. Presumably, a proper
treatment
| would need to include touch-down speed too, and perhaps
| gross weight as well.
| Its more than an academic question for me. My home airport
| has a 3 degree runway, and some local airports are even
| steeper.
Why not to land downwind [email protected] Piloting 23 September 6th 06 03:01 PM
Cuban Missle Crisis - Ron Knott Greasy Rider© @invalid.com Naval Aviation 0 June 2nd 05 09:14 PM
Pilot deviations and a new FAA reality Chip Jones Piloting 125 October 15th 04 07:42 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
