... Cubdriver wrote: On Mon, 09 Oct 2006 16:55:16 +0200, Mxsmanic wrote: So how do you know when you need it? Plane doesn't fly straight & level. Wants to lose altitude, less often to gain altitude. Or in a climb, wants to climb at an angle approaching stall. Or in a landing, wants to dive instead of glide. The great thing is to be able to hold the stick so lightly that your fingers aren't really touching it; the plane flies itself. The thing MXMANICDEPRESSIVE won't ever see with his simulator is how heavy the control forces will get with an out of trim aircraft. I forgot to set the trim to neutral once before takeoff in a C-172 (accidently skipped over it on the checklist), with my instructor on board... started down the runway, hit 55kts, and went to pull back to rotate, and was like "Wow!!! This is a lot heavier than normal!!!!" kind of like when you do touch and goes, and kind of thought to myself that my instructor had one too many doughnuts lately... Got the plane off the ground and climbing... Then I guess my brain was quickly rationalizing what could cause it to be so heavy, and glanced down and saw it had a fair amount of nose down trim (probably from the person who landed it before me), and went "Oh Crap!!!... forgot the trim!!!", and quickly took out a bunch of the nose down trim... :-) Was much easier to fly then. :-) You can bet I check that now everytime before take off. :-) You don't get this experience (how hard it is to pull the plane off the ground) in MSFS, and same for steep turns, first time I did steep turns (in C-172) I was shocked at how hard you have to pull on the elevator to maintain altitude, it seemed like it was probably at least a good 10 lbs, probably more. Reason I say it felt like when you do touch and goes, is you typically don't have time to reset the trim during a touch and go and kind of have to wrestle the plane off the runway and trim during the climb... Or at least I was not taught to reset the trim during a touch and go (while rolling on the ground), but taught to trim while climbing out, probably because if you reset it while on the ground you actually have to look down and a lot can happen in those few seconds you aren't looking out the windshield, and during the climb you can trim without having to look at the trim wheel and beside if you set it you will more than likely have to retrim on the climb anyway. Wade Hasbrouck PP-ASEL http://spaces.live.com/wadehas |
Wade Hasbrouck writes:
You don't get this experience (how hard it is to pull the plane off the ground) in MSFS ... You don't get it in all aircraft, either. If you know your aircraft well and you know it will do this, fine, but you cannot assume it as a general rule. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: You don't get it in all aircraft, either. If you know your aircraft well and you know it will do this, fine, but you cannot assume it as a general rule. WRONG AGAIN. You don't fly a REAL PLANE, so you DON"T KNOW. Allen |
Making a pitch trim indicator for a Glasair | [email protected] | Home Built | 5 | September 13th 06 02:30 AM |
Cherokee Electric Pitch Trim | Jonathan Goodish | Owning | 4 | November 18th 04 02:43 AM |
A very basic question | Ramapriya | Piloting | 45 | November 9th 04 01:57 PM |
Ramifications of Cherokee Trim Jackcrew Failure | Bob Chilcoat | Owning | 18 | June 9th 04 02:48 AM |
Lance vx. 6/300 | Bridgadoon | Owning | 27 | September 28th 03 08:20 PM |
