![]() Dylan Smith wrote: On 2006-10-13, Mike wrote: The type of aircraft he was in was utterly irrelevant. Smashing into a building in a Cessna 150 is just as fatal as hitting a building in a Cirrus, or a Learjet, or an ultralight. How do you know the aircraft is irrelevant? Please post your source. F=ma (force = mass x acceleration). Or in this case, deceleration. A 100kg human in an ultralight travelling at 25 metres/sec hitting a building and decelerating to zero in 0.5 sec (entirely plausable) will experience a force of 100 * 50 newtons (5,000 newtons) in the initial impact. Not to mention the bits of the building which are likely to shatter and pierce the body. But a force of 5,000 newtons against a human body is usually enough to kill. So it's pretty irrelevant whether a plane is a slow one or a fast one like a Cirrus - slamming (to use Lune's favorite word) into the side of a building is usually not going to be survivable. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de You've only argued that the type of aircraft was irrelevant at the point of impact. I think we can all agree on that! But that dismisses the possibility that this accident might not have happened if the aircraft had been slower - like a C150. (more time to react and less radius to turn, etc...). I don't believe this was a case of a pilot blindly flying into an object that was not easily visible from the cockpit (like hitting a mountain at night or in the fog). It seems more likely that either they were incapable of making the required tight turn (poor planning, staying ahead of the aircraft) and hit the building while trying to turn, or they lost control for some unknown reason (stall, aircraft malfunction, etc) and the building simply got in the way of the uncontroled flight/fall to earth. In either of those scenerios, aircraft type could very well be relevant. |
Faster airplanes can still slow down and be flown. There is
a reason to practice minimum control airspeed and slow flight. Traffic patterns are not the only time to pull the power back and or put some flaps down. See and avoid and scud running are much easier at 60-80 knots than at 180. All single-engine airplanes are required to stall below 61 knots. 23.49 (c) Except as provided in paragraph (d) of this section, VSO and VS1 at maximum weight must not exceed 61 knots for- (1) Single-engine airplanes; and (2) Multiengine airplanes of 6,000 pounds or less maximum weight that cannot meet the minimum rate of climb specified in §23.67(a) (1) with the critical engine inoperative. (d) All single-engine airplanes, and those multiengine airplanes of 6,000 pounds or less maximum weight with a VSO of more than 61 knots that do not meet the requirements of §23.67(a)(1), must comply with §23.562(d). So any single can be flown at 90 knots and have a safety margin in a 60 degree bank. http://selair.selkirk.bc.ca/aerodyna...in_Radius.html Remember the radius is in the middle of the river and you need to be smaller radius than half the river's width. wrote in message ups.com... | | Dylan Smith wrote: | On 2006-10-13, Mike wrote: | The type of aircraft he was in was utterly irrelevant. Smashing into a | building in a Cessna 150 is just as fatal as hitting a building in a | Cirrus, or a Learjet, or an ultralight. | | | How do you know the aircraft is irrelevant? Please post your source. | | F=ma (force = mass x acceleration). Or in this case, deceleration. | | A 100kg human in an ultralight travelling at 25 metres/sec hitting a | building and decelerating to zero in 0.5 sec (entirely plausable) will | experience a force of 100 * 50 newtons (5,000 newtons) in the initial | impact. Not to mention the bits of the building which are likely to | shatter and pierce the body. But a force of 5,000 newtons against a | human body is usually enough to kill. So it's pretty irrelevant whether | a plane is a slow one or a fast one like a Cirrus - slamming (to use | Lune's favorite word) into the side of a building is usually not going | to be survivable. | | -- | Yes, the Reply-To email address is valid. | Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de | | | You've only argued that the type of aircraft was irrelevant at the | point of impact. I think we can all agree on that! But that dismisses | the possibility that this accident might not have happened if the | aircraft had been slower - like a C150. (more time to react and less | radius to turn, etc...). I don't believe this was a case of a pilot | blindly flying into an object that was not easily visible from the | cockpit (like hitting a mountain at night or in the fog). It seems | more likely that either they were incapable of making the required | tight turn (poor planning, staying ahead of the aircraft) and hit the | building while trying to turn, or they lost control for some unknown | reason (stall, aircraft malfunction, etc) and the building simply got | in the way of the uncontroled flight/fall to earth. In either of those | scenerios, aircraft type could very well be relevant. | |
On Fri, 13 Oct 2006 09:23:46 -0700, cosmo_kramer1 wrote:
I think we can all agree on that! Balloon? - Andrew |
Trip report: Cirrus SR-22 demo flight | Jose | Piloting | 13 | September 22nd 06 11:08 PM |
Cirrus demo | Dan Luke | Piloting | 12 | December 4th 05 05:26 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Cirrus SR22 Purchase advice needed. | C J Campbell | Piloting | 122 | May 10th 04 11:30 PM |
New Cessna panel | C J Campbell | Owning | 48 | October 24th 03 04:43 PM |
