"Michael Horowitz" wrote in message
... I've taken my aileron apart and notice corrosion on the thin aluminum parts, so I'm reading around about cleaning prior to alodining. I've taken a stainless steel brush to the surface and removed most of the corrosion, but it's really a PITA. Someone suggested using lye as a cleaner. Anyone have any experience using supermarket lye in that role? - Mike I assume that this person is not a friend... I've used Drano to remove the remains of an aluminium piston from inside an iron cylinder (it was already bored to the max). It worked great... bye-bye aluminium. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Corrosion at Aluminum/Steel Junction | Front Office | Home Built | 17 | June 26th 06 01:12 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
